I'm having "issues" with Vectorworks 12.5.2, and I'm sure some are due to my newness to the program, however:
I have a new MacBook Pro (2.33 GHz Intel Core 2 Duo, 3 GB Ram) running OS X (10.4.9)
Here's what I'm experiencing since moving over to the "new, improved" Vectorworks "Designer" from my previous Vectorworks Fundamentals 11.5.2 (with which I experienced no problems, and was $950 richer...)
1) None of my palette locations or zoom preferences are saved between work sessions, and this is not document specific; it happens every time I open a new file from scratch, or re-launch an existing file from its folder location.
2) My work session ends, abruptly, whenever I use the "rotate" command, followed by the "Undo" command. As a matter of fact, oftentimes the use of Undo precipitates the "spinning beach ball" of oblivion, and I am required to "force quit" the program.
3) On relaunching the program, my previously saved Vectorworks file does not show up under the "open recent" menu; it can only be launched by utilizing the "open" command, and navigating to its folder location on my hard drive.
These are just the most recent issues (the ones I can recall) that have cropped up since the start of my work session two hours ago, and, as I mentioned above, were absent from my old version of Vectorworks.
I have run Apple's "Disk Utility," repaired preferences and even run "Disk Warrior," all to confirm that there are no problems with my Mac. I have 20 GB of empty space on my drive, so that shouldn't be a problem either.
Any advice would be much appreciated.
