Occasionally (although far too frequently) a field or two in a Label Legend 'shifts' out of place; ie the 'Channel' field is drawn immediately adjacent to a lighting fixture, but is rendered inches - or feet - away in the lighting instruments. It is inconsistent, but once it appears in a file it tends to recur with that Label Legend indefinitely - my only solution has been to manually shift the 'Channel' handle back to an appropriate location for every single lighting instrument using that Legend.
Things that have already been tried:
- I *have* re-created these Legends from scratch in VW2013 SP3. Leaves me clueless.
- I have deleted all Label Legends from a document, and then re-drawn the Legends from scratch.
Other tips:
- It seems to happen with *some* Label Legends on *some* instrument types/symbols. Could it have anything to do with the way an embedded symbol is rotated within the instrument symbol (ie a 'Source Four UP' symbol referencing a 'Source Four BASE' symbol)?
- If I attempt to counter the shifting back in the Legend (ie if the Channel dropped down 3 inches when rendered, I would try to shift it up 3 inches), the resulting render is seemingly senseless; it may fling the rendered Channel a dozen feet away or even 'flip' it across the 0,0 point of the symbol in the Label Legend.
Any thoughts? Thank you very much for your help.
Vectorworks 2013, SP3.
