I work with an office of 25 architects using VectorWorks 8.5.2 on Macintosh G4s running OS 9.04 and 9.1, and we too have this problem with panning and zooming. It happens on all of the computers, whose configuration vary only slightly. This problem is 100% reproducible.
It occurs in zoom views over 9000% in files about 700k, which is our average file size. In larger files, 4-5MB, the problem occurs predictable at views over 6000%. The problem can be reproduced by opening a file and zooming to over 9000% and then begin panning, using either the arrow keys or the hand tool. Around 20 clicks of the arrow button later, the application will freeze. The mouse is still movable, but you cannot click on anything. A force quit of VectorWorks will return you safely to the finder, which you can use without a problem. if you do not restart the computer, however, returning to Vector Works will almost immediately freeze the application. Restart the computer and you can go back to working in VW, until your zoom excedes 9000%.
If you zoom up to 20000%, it takes only 3 or 4 clicks of the pan tool to freeze the application.
Also, if you zoom to only 3000%, pan around a lot and then zoom to over 9000% it will freeze immediatebly upon executing the zoom. However, if you open the file, zoom to over 9000%, the freeze does not happen until after some panning has occurred.
I can reproduce this problem with these steps on all of the G4s in this office, with many different files.
I have done a lot of extensions troubleshooting to try to pinpoint a problem in the Mac OS. I have tried turning off each of the following in turn: all QuickDraw extensions, all 3rd party (non-apple extensions), all Quicktime extensions, All open GL extensions, all ATI driver extensions. The freeze continues to occur reliably, panning at views over 9000%.
Finally, I clean installed OS 9.1 and stripped the system down to the bare essentials. With only the Finder, the System Suitcase, MacOS Rom, System Resources and the Vector Works Prefs files, I could still reproduce the crash 100% of the time.
HELP!
