Stacy
    26
Reputation
0 Neutral
Personal Information
  • Occupation
    Draughts person
  • Location
    South Africa
  1. I'm still working on VectorWorks 11 and am going to buy a new PC. I was wondering if i should maintain working with Windows XP or upgrade to Vista. Could anybody tell me if Vectorworks 11 will run on Vista and if it does will it be better than running it on Window XP? Thanx
  2. Stacy
    Animations
    Ok thanx for the tip. Will just make sure once i'm finished everything i'll start with the animations.
  3. Stacy
    Animations
    I have created an animation to show clients the general idea of the model of the house and i was wondering if there is anyway to update the video once i've saved it and done changes to the house or is it easier to create a new animation? I'm working on VectorWorks 11.
  4. Stacy
    Hatch
    I'm working on VectorWorks 11. Is that function only on VectorWorks 12 or will 11 have it as well.
  5. Stacy
    Hatch
    Is there a way you could convert lines to a hatch instead of creating it in the edit hatch function?
  6. Stacy
    Hatch
    How do you set a hatch Origin?
  7. Stacy
    Tables
    A table as in a spreadsheet. Thanx
  8. Stacy
    Tables
    I was wondering if VectorWorks offers the function of ready made tables, like inserting a door all you need to do is edit the number of rows and columns.
  9. Stacy
    Roof
    The roof that I'm trying to compute is simple. It allows me to create the roof but it doesn't allow me to edit certain areas of the roof.
  10. Stacy
    Roof
    I keep getting an error message Could not compute roof, house drawing too complex to compute roof. All I'm trying to do on the roof is change part of the roof to a gable end with a 100mm overhang. I can have one or the other it won't allow both options.
  11. Stacy
    Memory
    No, I'm no longer having problems with the viewports. Thank you for all the help.
  12. Stacy
    Memory
    Yes I am on PC, sorry I should have specified that. The error message says, One or more viewports could not be rendered. One or more operations was aborted due to lack of memory.
  13. Stacy
    Memory
    The file that I'm working on is 4.5MB. I'm working on a Pentium 4, 2.8GHz, 1GB RAM, with FX 5200. The viewport DPI was set on 750 with the 3D resolution on low.
  14. Stacy
    Memory
    By selecting "wire frame" and then re-selecting Open GL doesn't clear the buffer I have to restart my computer. I have changed the settings to medium and will see if that helps. Thank you
