lha
    8
    Never
Everything posted by lha
  1. lha
    Stair Railings
    Thanks for your response. I am running VW 12.5 on Mac OS 10.4. The file in question is set up for for 3-D. When the first level layer is active, the handrails are shown. When the second level layer is active they do not appear. I have checked the classes visibility and that doesn't seem to be the problem. Any other ideas? Thanks Again
  2. Does anyone know why my handrails only appear on the lower level stair view and not in the upper level design layer? Thanks
  3. Help someone! How can I apply a hatch to a wall while viewing the wall in elevation? This is my first attempt at hatching and I am quite confused about how it is done in VW.
  4. lha
    insertin window
    Thanks! I had the active layer set to doors/windows. I knew it had to be something silly like that! Duh! Thanks for the help!
  5. lha
    insertin window
    Thanks for your response Katie. The window is definately not in the wall and even with the object cursor cue the window will not insert into the wall. Although new to VW I have inserted plenty of windows in walls and am stumped as to why it isn't working now. Any more ideas?
  6. lha
    insertin window
    Yes, I have checked that wall insertion mode is selected. Thanks though, any more ideas?
  7. I am new to VW and I know there is a very obvious answer for this but, alas, I cannot figure it out. When I insert a window in a wall there are no breaks in the wall so it appear that the window has not been inserted. The manual says I can change the break in the Obf info palette but that option (along with flip and position) do not appear. Help!
  8. I have two walls stacked one on top of the other and there is a horizontal line between them in hidden line view. They should read as one wall and adjacent walls on a different face of the building model also stacked show correctly. Any suggestions? I have checked the properties of the walls and compared them to those that show up correctly and still can't figure it out.
