littlenev
    5
Reputation
0 Neutral
  1. Hi folks Does anyone have any idea why when I set the 'Certain' style of sketch as default and then save the drawing, why when re-opening the file, does the sketch style revert to the over exagerated 'rough' style? This never happened with ver 12.5! Regards littlenev Using Vectorworks 2008 (Architect & Renderworks)on Windows XP64 OS
  2. Yes wheel works in other applications including vectorworks. Having just openned 12.01 again, I note that I am getting the same functions working ( the drop down list does not scrole with the mouse wheel, only the scrole bar, so maybe that is all I should be expecting. The object info palette itself does scrole with the wheel. Main difference between 12.5 and 12.01 appear to be the width of the drop down box - in 12.01 the scrole bar always remains visible and font descriptions begin to dissapear when the palette width is decreased. - In 12.5, the scrole bar dissapears and font description remains visible. Not a major problem, but visible workin area is reduced in width by 15mm
  3. Using windows XP64 on 64 bit machine. I also have palette docking enabled and the problem has only occured since changing to 12.5 from 12.01
  4. Thanks Yes I get scrole bars to appear - at the cost of working area for drawing and the mouse wheel still does not appear to scrole the drop down lists!
  5. In VW 12.5 I am finding that when the Object Info palette is docked to the right hand side, I cannot scrole the fonts - the scrole arrow is hidden (off the screen) and the mouse wheel fails to scrole! Similar situation with the resource browser. Is it just me?
