mar schrammeyer
387 -
Posts posted by mar schrammeyer
thanks michael indeed
i use hidden line rendered VP annotate with polygon bucket hatches without fill change VP rendering to artistic lines & shadow have a sun class for each quarter
thanks michael but that is not what i ment under VP rendering options artistic render default is cartoon so one has to go through the motions every time to get like in my case lines & shadows with shadows aluminium
Is it posible to change the default artistic rendering for me it is set to cartoon and i would like to change it.
option-shift-8 on my mac
you will drink less coffee, no time to make it
lovely that paint bucket use it on a hidden line rendered VP then copy & paste in place VP remove all anotations and change render to artistic lines & shadow send to the back (make sure hatches have no fill) lovely i use 4 suns, one in each quarter (as class)
check this site for metal roof textureshttp://www.steelselect.com/textures.php
and yes i do, front page, shadow diagrams etc the lot
my apologies jonathan indeed i did not install vaanz upgrades
sorry katie made a statement i solved my problem but don't understand why it occurred and yes johnatnan i reinstalled the full suit including vaanz
reinstalled twice (cd &12.5 upgrade) to my mac book pro and vw would not work no select similar (error message where is plug in folder) and could not set sun position did a check by repeating the process on g4 iBook same thing therefore my conclusion
there is a post saying one cnnot upgrade to 9.5 from 9 one has to go from 9.1 to 9.5 ergo
make sure you get also the 12.1 udate before updating to 12.5
ok fixed the problem missed upgrade 12.1 reinstalled by firewire and everything ok
i fire wired my computersettings etc over from my G5 Imac to my new mac book pro but things where missing from VW like layer view keyboard short cuts & i get an error message when trying to use select similar tool, reinstalled VW from cd & up graded to 12.5 but still the same problem any idea what i can do?
i fought a weekend with VW crashing while annotating section viewport (live away from internet) the solution was to set autosafe to 10 operations instead 15 min, might this be a ram problem?
G5 1.6 G iMac 1G ram OS10.4.8 VW 12.5
turn quartz off
thanks a lot
after several hours work VW12.5 gets tired and stops pasting from clipboard closing & reopening VW fixes the problem but very anoying any one ?
my stairtool is now very sluggish depending complexity stairs (spinning ball even between tabs) but the up/down arrow extend now to last tread and that is a nuisance to hide (having an arrow in a cupboard can be hard to explain) anybody ?
see archoncad podcast 012 , i would recommand to eliminate the curves of the original i-beams & channels they become a bit easier to render
thanks for the replies i had to duplicate and move a similar wll on that layer just redoing would give the same result
when i try to fit wall to roof i get two spikes downward to minus wall height manually i can not add a vertex, same problem, it does not happen with every wall in the file
Faceted stringers on curved stairs
in Architecture
Posted
nice, this works also on straight stairs, were they ugly
