Inventor
    5
Everything posted by Inventor
  1. I am trying to fillet a 3-D edge. I tried to do it with a basic shape to simplify the problem but was unsuccessful. I followed the directions correctly, I believe. Create an extruded rectangle of 1x2x2 inch --> convert to NURBS --> ungroup --> select fillet edge tool --> select 0.1" radius and faces option --> then I selected two adjacent faces and entered. The message read "edge filleting failed". I tried various options. Not sure what I doing wrong. I have Windows XP, VW 11.5 with Renderworks.
  2. I just sent you a file. Op system is XP and VW 11.5.1 with Renderworks. The problem seems to occur only in certain layers - especially ones with a lot of other work already occupying space. If I copy the problematic objects from one lay to a new layer, sometimes I can solve the issue.
  3. I use VW 11.5. Very frequently I have a problem adding and clipping some of the simplest of shapes. When I add a rectangle to a circle, sometimes nothing happens, sometimes one or the other disappears. Sometimes when I clip a moderately complicated shape (such as one that has been clipped before), it results in a bizzare twisted shape. The shapes are neither locked or grouped. This happens even before I use any 3-D commands in the program itself; in other words, when I am just sketching the design. What is going on? Is there something else that I need to check?
  4. I exported a simple logo as an EPS file to my designer. She modified it and I tried to import the file back in. A message came up advising the it was not a valid EPS file. I am working on a Windows Xp. My designer is on a Mac. Does Vectorworks 11.5 accept all versions of EPS?
