wellebracht
    5
Everything posted by wellebracht
  1. So, I've used the Nomad app a bunch of times for LiDAR scans and importing into Vectorworks, and it works great. However, I have received a .ply file from a client that does not have any color in any of the points in Vectorworks. I have imported the .ply file in other programs, like CloudCompare, and all the points have color. The point cloud object Color Scale in the OIP is set to "Original." Is there another setting somewhere that I have to set to get the color date, or is it an issue somewhere else?
  2. This is a Vectorworks Worksheet that I am trying to duplicate, but the list data I am grabbing from an outside Excel Sheet. I have made a worksheet that counts certain symbols inside Rooms that I'm using as a key, that I want to duplicate/rename from provided list and place on corresponding Sheet Layer. Excel Reference.xlsx Excel Reference Marionette.vwx
  3. Hello! So, I'm trying to create a Marionette system to grab data from an Excel from a particular row, grab that data into a list, and use that list to create/duplicate/rename Sheet layers, design layers, and worksheets. I have the design layer and sheet layer side if it working properly, but I'm a little stuck on the worksheet part. There are some nodes I have found to select symbols, or duplicate objects, but none of them seem to grab a worksheet handle (i know a worksheet is not a symbol, but i tried anyway). Anyone have an idea on how I can accomplish the remainder of this task?
  4. So, I'm not sure if I just am filling out the formula incorrectly, or if I'm running into a bug. I cannot seem to get the =GetSpaceNameforOBJ function to work within a report. I can filter a report with that criteria, and it works just fine, but I cannot seem to get that same data to appear within the spreadsheet itself. Am I just using the wrong context within the spreadsheet?
  5. Is there a way for me to add a filter to a worksheet or equipment summary key that will only count the symbols that exist within a Space Object? I have about 34 separate rooms with a slightly different layout in each room, and would like to have a worksheet or equipment summary key filter out all the gear I have within each room independently.
