acardoza
    8
Reputation
0 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
323 profile views
  1. This would make more sense, that may be what happened. Thanks!
  2. I realized that all the connections for several devices turned into individual objects (polygon, text) and removed it's circuit data. I think what may have caused this was moving devices with connections into different design layers. I cant seem to replicate the problem on a new file. Any ideas?
  3. When moving a 3D rack with rack frames to a different design layer, the equipment moves out of the rack frame or the rack frame moves. Therefore making you have to redrag the equipment back into the frames. Rack Frame Test.vwx
  4. Thanks! This works. It would be great to have the rack mounted panel connectors work like equipment items and snap into the racks for a more simple workflow.
  5. Attached is a test file. I've discovered that panels can show up in rack elevations when changing the classes in the viewport. Connector Panel Test v2.vwx
  6. Can Panel Connectors be linked to a 3D Rack? When creating a panel layout you can make it rackable (RU and width entry) but it doesn't snap or assign to a Rack in the drawing. It would be great to link to a rack like any other piece of equipment can link from schematic device to Equipment to Rack. Also, without being in a rack it doesn't show up when creating a Rack Elevation through ConnectCAD.
  7. I have been changing the fill attribute for the text box in the panel layout edit, but when exiting the panel layout the fill returns. Is there a different way to achieve no fill on the text? Thanks Connector Panel Test.vwx
  8. On the linked text fields (Ex: Device Name) on the new 3D connector panels it seems like there is a solid white fill behind the text even if you change that attribute in the device. Is there a way to remove the white fill?
