Jrw
    11
Reputation
0 Neutral
Personal Information
  • Location
    Australia
  1. No problem, understand. Thanks for the confirmation. Hopefully this will be a feature in the future. Below is only my opinion...hope it helps in some sense: Another way could be change the 'connectors on cables' to be the connector itself. Because in reality, people would know the connection method and connectors used to terminate the cables onto specific 'connectors'. So the connector type itself is the most important part. I have not seen a way to put this info in except in 'device name' or 'socket name'...the input field for 'connector on cable' could just be connector itself, much easier for providing infos...
  2. Hi @Conrad, Yes they are the same as sockets on devices but sockets are fine as they will only have one side connection, whereas term panels normally have both side connections which may require different connection methods. It sounds like it cannot be done in current version? Can I hide the connectors on a specific circuit instead?
  3. Hi @Nikolay Zhelyazkov, No it will only remove the connectors on the right hand socket but will still leave the connectors for the left side connection, which are the ones I want to remove. I cannot set the left hand sockets to '---' because I still want the 'IN' side to have the connectors shown. Any ways we can do this?
  4. Hi, I have connectors having two connections, but it should have connectors on one connection but no connectors on the other connection. Is it possible to hide connectors on the other circuit? For example, the left side circuit has "XLR3M" connectors which are correct but the right side circuit should not have connectors - they are soldering to the connectors' back. How do I hide them? Currently once I select the connector types on the socket they are showing 'XLR3M' on both end.
  5. Hi guys, I am numbering cables via ConnectCAD > drawing > number cables...I know we can use spotlight numbering to manually do it however, this is quicker as it's automatic labelling. However, it starts from 9001 every time, is there a way I can change it to follow my rule, say starts from 001?
  6. Hi @Nikolay Zhelyazkov , Thanks it basically solved the issue. I wish it could know to adjust its location to the horizontal line instead of offsetting from the endpoint vertically 🤣 I guess it's good enough for now. Thanks.
  7. Hi @Nikolay Zhelyazkov, Yes it kindly fixed the problem a bit but now the number is overlapping with the connector types...see below. I guess it was not shown originally because of this. Is there a way I can fix this?
  8. Hi, I used 'ConnectCAD' > Drawing > Number Cables...to automatically number all the circuits. However some cable numbers are not shown on the drawing, they do have been numbered according to the circuit report. Also tried to use 'spotlight numbering' still not shown. See below - there are 4 circuits but there is only one number shown for the last circuit. Anyone know how can I fix this?
  9. Is there a way we can get rid of the bubbles? The bubbles are two small and will not be seen when printing out the drawings, but we do need the cable infos stay in the system for cabling report...Cannot find anywhere in the software to hide it... Can anyone help please?
