mlohse
    4
Reputation
1 Neutral
Personal Information
  • Location
    Switzerland
Recent Profile Visitors
  1. solved, tryed with entity Matrix and got the results i expected 👌🏼
  2. Hello together, im trying to rotate the Lighting Device same way as the Truss Item is and cant figure out what's going wrong. maybe someone can give me an idea? Thanks a lot
  3. close the Curve and Loft Surface was the Way to go, thank you very much have to organize the Network, actual its a mess 😄 next problem I have is the file size, (empty file with the network is round about 300MB) and I don't know why... and the time Vectorworks need to recalculate the model, if I enter the parameter is too long (10 seconds or more of colorful ball rotation).
  4. Hello together, im new to Marionette and can't find a good solution for my problem, maybe you can open my eyes. I can draw a nurbs curve from 4 3D Points, (pt1,pt2,pt3,pt4) (rectangle) and another one from 3 points (triangle or arc, based on the degrees being 1 or 2), start point from the arc is pt2 and endpoint from the arc is pt3 from the rectangle. i want to get a closed surface from the merged figure, but I don't know how. maybe someone can help me. best regards.
