Hi,
I am trying to use the native cable tools in VWX '23 and I get to the point where I run the multi from the distro, but when I click on the path, it sends the cable thousands of feet away before it comes back to the breakout.
I've placed the distro on the ground, put the breakouts in the truss, the trim is 30', and I have set a Cable Path from the distro to the end of the truss per the instructions in the tutorial from 2022. Now, as I understand it the process of clicks to run a multi is as follows:
Click the distro, then select the port
Click the cable path, the cursor will automatically move to the end
Click the truss you're going to run along**
Click the breakout you want to connect to.
**When I click the truss, the cable path is drawn thousands of feet away from where I am working, then when I click the breakout it draws a giant acute angle from that random point back to the breakout. I have checked and there are no objects anywhere out there where it's sending the cable path.
Any thoughts?
