John Windswept Design
206 -
Posts posted by John Windswept Design
You should see the crazy animations I'm getting. Most have nothing past the first frame others are scrambled. Seems buggy. I'll attach one but you have to change the jpg to m4v. I'll try replacing that file now to see if I can get a more reliable output. Glad I promised that animation on monday.
john t
I've been working in SP3 for months with no issues and I've just updated to SP4. Now I can't get the animation to work and I've also had my first crash in months. If replacing agent.app with help then much appreciated.
john.t
I seem to only get the first frame on my solar animation. The movie will play for one frame then the rest of the movie is blank. Any ideas?
NAILED IT!!! Great thanks. But don't change the wall direction while in hidden render 10min and counting...
Thanks very much.
john t
Any ideas on what is happening?
Here is an elevation from a project started a week later and they show up. ohoh is this a bug?
Actually they are not there in final render either ;-). I'm stuck..... Can't find anywhere to toggle this...... help
So I have narrowed it down a little. It has nothing to do with the viewport and everything to with the hidden rendering. If I do a hidden render of the model the operation line disappear. If I do any other rendering they are there. I just checked on another project and the operation lines show up on hidden render. Is there a toggle for this somewhere?
john t
Any help will be greatly appreciated as I need to issue the drawings on monday!
Here are some screen shots
I checked other projects and they show up. I'm miffed. I turned all the classes on in the view ports and they still didn't show up. Doors and windows.
Hi I asked this before and I received no answer. My window direction is not showing up in my section viewports (elevations). They shows up when I rotate the model around and are toggled to show in 3d. Please help before is have to go in a draw them.
john t
A large portion of my houses seem to be putting in Tilt and Turn windows. How do I get my schedules to represent this under "sash operation" as there is no option for T&T windows? This is becoming big for me.
Also I want to add a new column to my schedule to pick up transoms and the size of the transom. I know I should know this by now.
Regards
John T.
Hi All,
I've set the "show direction in 3d" toggle to on for my doors and in the 3d environment the door direction does shows up.. But in my elevations(section viewport) and sections the door direction does not show up. Is there a setting I'm missing?
John T
Thanks Peter I'll give it a try.
Yes but I want the lower section to be filled. The stair tool.
When breaking a stair to show the top part as doted. I would like to show the closet underneath and the dotted part is filled. Is it possible to have just dotted lines for upper break portion.
john t
Can you put a skylight in a roof face (pio)? I tried to no avail.
john t
hmm so it is still not working. Maybe I'll just start a new drawing and import this file. might fix it
I've attached a screen shot. I'm working in layer plane and the animation option is set correctly. I still can't get the movie to work properly. It is centring at the blue grid
jt
I want to make a movie that rotates around my building or orbital point. My building sits right on 0 y and 0 x. Even the red, green and blue lines seem to be located in the right spot. But the movie rotate around another point and I can see a blue grid at the point. Help!
john t
How do you get the window tags transferred from the plan to the elevations?
That's not a bad work around. Thanks
Every district I've worked with has required window sizes in elevation. It would be a huge time saver.
Solar Animation
in Architecture
Posted
Changing the .app didn't effect the animation. I'm still getting blank spaces in my animation.
