Dexie
    175
Everything posted by Dexie
  1. Has no one ever used this feature. In the video it looks quite simple but just doesn't work in reality.
  2. I would like to use the modify by record value option as seen in the YouTube video tutorial... I have some simple house type symbols with record format attached:- Name, Storeys, Gross floor area etc. and would like to use the modify record command to display each of these as different colours. When I use the modify record value option, nothing happens. I don't understand how the command knows what part of the symbol to modify. Within the symbol I have a polygon representing footprint which is by class which I would expect to change colour. Should the record be attached to this polygon and not the symbol itself? Any help would be appreciated.
  3. Is it possible to change all objects within selected symbols to NO SKETCH. Jonathan Pickup kindly posted a script to display all objects in symbols by class. Is there a suitable scrip to change objects in multiple symbols to No Sketch?
  4. In the UK the Ordnance Survey provides building height data for any mapping data purchased. This comes as a .csv file and .csvt file. I believe this can be used with GIS software. Is there anyway this useful data can be accessed in Vectorworks? I can't attach the file because of the .csv file extension but the data is included below. If anyone has any suggestions I am sure this would be useful to many VW users. os_topo_toid,os_topo_version,bha_processingdate,tileref,abshmin,ahsh2,abshmax,relh2,relhmax,bha_conf 0001000028180690,2,10/08/2013 00:00:00,SP38SW,116.2,118.7,120.3,2.5,4.1,99 0001000028180691,2,10/08/2013 00:00:00,SP38SW,116.2,120.1,121.4,3.9,5.2,99 0001000028180699,2,10/08/2013 00:00:00,SP38SW,115.3,118.9,120.4,3.6,5.1,99 0001000028180704,2,10/08/2013 00:00:00,SP38SW,115.8,122.5,125.2,6.7,9.4,99 0001000028180705,2,10/08/2013 00:00:00,SP38SW,116.1,119,121.8,2.9,5.7,99 0001000028180706,2,10/08/2013 00:00:00,SP38SW,116,121.4,122.4,5.4,6.4,99 0001000028180707,2,10/08/2013 00:00:00,SP38SW,115.2,122.9,127,7.7,11.8,99 0001000028180708,2,10/08/2013 00:00:00,SP38SW,115.9,118.7,123.1,2.8,7.2,99 0001000028180709,2,10/08/2013 00:00:00,SP38SW,115.8,119.3,122.3,3.5,6.5,99 0001000028180710,2,10/08/2013 00:00:00,SP38SW,115.1,122.8,126.1,7.7,11,99 0001000028180713,2,10/08/2013 00:00:00,SP38SW,114.5,121.1,127.2,6.6,12.7,99 0001000028180714,2,10/08/2013 00:00:00,SP38SW,114.7,120.7,121.9,6,7.2,99 0001000028180717,2,10/08/2013 00:00:00,SP38SW,107.8,122.3,124.7,14.5,16.9,99 0001000028180718,2,10/08/2013 00:00:00,SP38SW,107.9,120.2,123.4,12.3,15.5,99 0001000028180719,2,10/08/2013 00:00:00,SP38SW,108.1,117.3,121.6,9.2,13.5,99 0001000028180720,4,10/08/2013 00:00:00,SP38SW,114.4,121.5,130,7.1,15.6,99 0001000028180728,2,10/08/2013 00:00:00,SP38SW,115.7,124.3,127.1,8.6,11.4,99 0001000028180729,2,10/08/2013 00:00:00,SP38SW,115.8,123.1,126.6,7.3,10.8,99 0001000028180732,2,10/08/2013 00:00:00,SP38SW,112.9,115.9,117.5,3,4.6,99 0001000028180734,2,10/08/2013 00:00:00,SP38SW,115.3,120.5,125.7,5.2,10.4,99 0001000028180735,2,10/08/2013 00:00:00,SP38SW,115,123,125.7,8,10.7,99
  5. Thanks for that, it makes sense. But is there a way limiting all calculations to using 2 decimal places rather than 4 or 5 if you see what I mean. I suppose I should have entered the actual value for acres rather than the figure derived from from converting hectares to acres.
  6. I have a simple worksheet which does some calculation for a development site. All columns seem to match except the final calculation to work out the square footage per acre, Value=F24/D27 (43692/2.30acres) Result = 19012.807 Which is wrong But if I put F24/2.30 Result = 18996.522 What is going on, I need to rely on these figures being correct. Any ideas?
  7. Thanks for the reply I will give it a try and report back tomorrow. Also for the reminder to update my profile.
  8. I have access to LIDAR Data for a site which comes with the file extension .asc. Is there any way that this can be used within Vectorworks. If I import survey data it gives an error. I have imported other x,y,z data before with success. This data starts like this: ncols 1000 nrows 1000 xllcorner 599000 yllcorner 227000 cellsize 1 NODATA_value -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 ...many row of this... then what looks like data.... 43.805 43.795 43.792 43.815 43.838 43.805 43.750 43.738 43.730 43.720 43.708 43.697 43.710 43.690 .... then more of the -9999 -9999 -9999. Anyone have any ideas. The data may well be to heaven to use in VW.
  9. Thanks Pat I will give it a go, hopefully it will work with these symbols. Thank you for taking the time to help with this and many of the other queries I have posted over the years.
  10. I have imported a whole load of symbols from AutoCAD within which all objects are of a class but are not displayed with class defaults e.g. The class for down pipes is blue line and 0.05mm but displays as 6mm. Is there is a script that will convert all these objects as the class default of 0.5mm and blue or do I have to manually go into every symbol and change everything to Make All Objects By Class.
  11. I would like create 2D symbols with the ability to switch on a drop shadow (pretty much the way a plant symbol works) so that when the symbol is rotated the shadow repositions to the same location and the amount of offset can be controlled. Has anyone seen something like this or know if it is possible. I would like to drop vehicle symbols onto a plan and give them a bit of depth.
  12. I think the way to go is with separate symbols for each of the variations in house type as suggested. It will probably be easier to keep track of each type used in a layout and to create a report etc. Thanks for all your suggestions.
  13. Is it possible to produce a house type symbol which can have different configurations of the same basic building but with variation that can be controlled in the object info palette,e.g. End terrace (left handed), End terrace (right handed), Mid terrace (left handed) and Mid terrace (right handed)? I know that I can mirror symbols but I would like each type to be identified as a separate unit in a schedule. Or is this in the realm of the PIO. If so is it very complex to achieve. I believe AutoCAD can do something similar within its blocks.
  14. Is it possible to format the 'NUMBER' field in the Property Line object info palette to contain a trailer. I want to display a number e.g.(60) with a trailer e.g. (units) so that when exported as a report these figures can be totaled in the worksheet. If you right click in the 'NUMBER' field you have various options e.g. substitutions, smart quotes, smart links, data detectors, what are these for?
  15. I have had complaints from some of my colleagues concerning crashing whilst exporting to .dwg when a drawing contains an image fill. We have tried this on a few same spec iMacs with the same result. But works on an older model iMac which has 32GB of RAM. I have included the below the error message displayed after the crash. I'm sure it means something to someone. If you have any ideas I would be very interested. Process: Vectorworks [440] Path: /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/Vectorworks Identifier: net.nemetschek.vectorworks Version: 20.0.3 [257190] (20.0.3) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: Vectorworks [440] User ID: 501 Date/Time: 2015-06-26 16:13:45.667 +0100 OS Version: Mac OS X 10.10.3 (14D136) Report Version: 11 Anonymous UUID: BDB0264C-5A72-30B5-6AD8-B96CB7E0F531 Time Awake Since Boot: 5400 seconds Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 VM Regions Near 0: --> __TEXT 0000000101b50000-0000000104557000 [ 42.0M] r-x/rwx SM=COW /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/Vectorworks Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 net.nemetschek.vectorworks 0x00000001036c2108 CreateNurbsCurveFromPolyline(PolylineType**, bool, bool) + 1816 1 net.nemetschek.vectorworks 0x0000000103528979 DWG_GS_Kludge(int, void*, void*) + 61001 2 net.nemetschek.vectorworks 0x000000010351a06a DWG_GS_Kludge(int, void*, void*) + 1338 3 net.nemetschek.vectorworks 0x0000000103553405 CB_Kludge + 18213 4 net.nemetschek.vectorworks 0x00000001034381b3 VectorWorks::CSDK::Kludge(short, void*, void*) + 19 5 net.nemetschek.vectorworks. 0x00000001158a68f8 CreateNurbsCurveFromPolyline(char**, bool, bool) + 229 6 net.nemetschek.vectorworks. 0x000000011584061b DWG::TADExport::WritePolylineNodeByVersion(OdDbObjectId const&, char**, TransformMatrix&) + 169 7 net.nemetschek.vectorworks. 0x00000001158395a4 DWG::TADExport::WritePolylineNodeNew(OdDbObjectId const&, char**) + 1296 8 net.nemetschek.vectorworks. 0x00000001158325e8 DWG::TADExport::DispatchNode(OdDbObjectId const&, char**, unsigned int) + 5246 9 net.nemetschek.vectorworks. 0x0000000115829666 DWG::TADExport::PostorderTraverse(OdDbObjectId const&, char**, unsigned int) + 538 10 net.nemetschek.vectorworks. 0x00000001158309b5 DWG::TADExport::WriteBlockToList(DWG::TGrouplikeInfoAndID&, DWG::TADExport::TBlockID&) + 3993 11 net.nemetschek.vectorworks. 0x00000001158146fb DWG::TADExport::WriteBlockSection() + 841 12 net.nemetschek.vectorworks. 0x000000011581054d DWG::TADExport::DoWrite() + 2009 13 net.nemetschek.vectorworks. 0x00000001157b07e6 ExportDXFMenuItem(short, VectorWorks::Filing::IFolderIdentifier**, TXString const&, VectorWorks::Filing::SExportOptionsForPublish*) + 1692 14 net.nemetschek.vectorworks. 0x00000001157a473d ExtDWGLibrary::CDWGLibraryRoutines::ExportDXFDWG(VWFC::PluginSupport::VWPluginLibraryArgTable&) + 69 15 net.nemetschek.vectorworks. 0x000000011596cba7 VWFC::PluginSupport::VWVSFunctions_EventSink::Execute(int, PluginLibraryArgTable*) + 167 16 net.nemetschek.vectorworks 0x0000000102aaa707 CExternalsDefFile::Call(int, PluginLibraryArgTable*, int&) + 23 17 net.nemetschek.vectorworks 0x0000000102abf414 TParametricExternalsHandler::Call(PStr<63ul> const&, PluginLibraryArgTable*, int&) + 228 18 net.nemetschek.vectorworks 0x000000010354e198 CB_CallPluginLibrary + 88 19 net.nemetschek.vectorworks 0x0000000103437b93 VectorWorks::CSDK::CallPluginLibrary(TXString const&, PluginLibraryArgTable*, int) + 35 20 net.nemetschek.vectorworks 0x0000000103b1c514 CallProcLink::CallDynamicProc() + 1700 21 net.nemetschek.vectorworks 0x0000000103b1d6c4 CallProc(TableEntry*, TableEntry*) + 148 22 net.nemetschek.vectorworks 0x0000000103aed806 ResumeScript() + 9734 23 net.nemetschek.vectorworks 0x0000000103aedf7f RunScript(TScriptModule*) + 671 24 net.nemetschek.vectorworks 0x0000000103a3b169 RunTheModule(TScriptModule*, short, unsigned char, FormatType**, RecordType**) + 2313 25 net.nemetschek.vectorworks 0x0000000103a3c13d CompileAndExecuteFile(TFileIdentifier const&, unsigned char, unsigned char, void (*)()) + 1613 26 net.nemetschek.vectorworks 0x0000000103a3c4aa ExecuteMacro(TScriptModule*, unsigned char, unsigned char, void (*)()) + 394 27 net.nemetschek.vectorworks 0x0000000102ab86c1 TParametricExternalsHandler::CallParametric(short, char**, char**, ParametricMessage*, ToolMessage*, void (*)(), unsigned char) + 3089 28 net.nemetschek.vectorworks 0x00000001027a5be6 LLCallMenuCommand(CoreMenuCommand&, MenuMessage&) + 3302 29 net.nemetschek.vectorworks 0x00000001027a6436 TMenuBar::CallMenuItemByIndex(short, MenuMessage&) + 982 30 net.nemetschek.vectorworks 0x00000001027a685b TMenuBar::ExecuteMenuCommandByHash(short, short, short) + 315 31 net.nemetschek.vectorworks 0x00000001027a6cd7 TMenuBar::ExecuteMenuCommandByID(short, short, short) + 183 32 net.nemetschek.vectorworks 0x0000000101c5468e MoreSecExecuteRequestInHelperTool + 4334 33 libsystem_trace.dylib 0x00007fff88aa6cd7 _os_activity_initiate + 75 34 com.apple.AppKit 0x00007fff8a03efb1 -[NSApplication sendAction:to:from:] + 452 35 com.apple.AppKit 0x00007fff8a03ed4e -[NSMenuItem _corePerformAction] + 382 36 com.apple.AppKit 0x00007fff8a03ea7c -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114 37 libsystem_trace.dylib 0x00007fff88aa6cd7 _os_activity_initiate + 75 38 com.apple.AppKit 0x00007fff8a105c10 -[NSMenu performActionForItemAtIndex:] + 131 39 com.apple.AppKit 0x00007fff8a105b76 -[NSMenu _internalPerformActionForItemAtIndex:] + 35 40 com.apple.AppKit 0x00007fff8a1059c2 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 107 41 com.apple.AppKit 0x00007fff8a026e6b NSSLMMenuEventHandler + 724 42 com.apple.HIToolbox 0x00007fff92b79b6c DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1260 43 com.apple.HIToolbox 0x00007fff92b78fae SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386 44 com.apple.HIToolbox 0x00007fff92b8ecb6 SendEventToEventTarget + 40 45 com.apple.HIToolbox 0x00007fff92bc8f45 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 428 46 com.apple.HIToolbox 0x00007fff92c06b8d SendMenuCommandWithContextAndModifiers + 59 47 com.apple.HIToolbox 0x00007fff92c06b30 SendMenuItemSelectedEvent + 188 48 com.apple.HIToolbox 0x00007fff92c06a09 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 49 com.apple.HIToolbox 0x00007fff92c07481 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 702 50 com.apple.HIToolbox 0x00007fff92c070fe _HandleMenuSelection2 + 446 51 com.apple.AppKit 0x00007fff89f44de0 _NSHandleCarbonMenuEvent + 277 52 com.apple.AppKit 0x00007fff89e7bd0d _DPSNextEvent + 1828 53 com.apple.AppKit 0x00007fff89e7af68 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346 54 net.nemetschek.vectorworks 0x0000000101cc2271 CWSFieldChoicesList::CWSFieldChoicesList(TXString const&, TXString const&) + 134193 55 com.apple.AppKit 0x00007fff89e70bf3 -[NSApplication run] + 594 56 com.apple.AppKit 0x00007fff89ded354 NSApplicationMain + 1832 57 net.nemetschek.vectorworks 0x0000000101b52684 start + 52 Thread 1:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x00007fff912cf232 kevent64 + 10 1 libdispatch.dylib 0x00007fff8f75ea6a _dispatch_mgr_thread + 52 Thread 2: 0 libsystem_kernel.dylib 0x00007fff912ce33a __recvfrom + 10 1 net.nemetschek.vectorworks 0x00000001022eea64 TSerialNumServer::ReceiveQuery(TSocket*, TSocketAddress&, bool*, unsigned short*) + 84 2 net.nemetschek.vectorworks 0x00000001022eecc9 TSerialNumServer::StartThread() + 281 3 net.nemetschek.vectorworks 0x00000001022ef439 TSerialNumServer::Start(std::__1::deque, std::__1::allocator >, std::__1::allocator, std::__1::allocator > > > const&, int, std::__1::basic_string, std::__1::allocator > const&) + 873 4 net.nemetschek.vectorworks 0x00000001022f38c0 TThread::StartThread(void* (*)(void*), void*) + 160 5 libsystem_pthread.dylib 0x00007fff8621e268 _pthread_body + 131 6 libsystem_pthread.dylib 0x00007fff8621e1e5 _pthread_start + 176 7 libsystem_pthread.dylib 0x00007fff8621c41d thread_start + 13 Thread 3: 0 libsystem_kernel.dylib 0x00007fff912c951a semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff8f762c55 _dispatch_semaphore_wait_slow + 213 2 net.nemetschek.vectorworks 0x00000001022f3634 TSemaphoreNew::Wait(unsigned int) + 52 3 net.nemetschek.vectorworks 0x00000001022f3b43 TThread::WaitForSemaphore(TSemaphoreNew*, unsigned int) + 19 4 net.nemetschek.vectorworks 0x00000001022ea272 TLicenseVerifier::StartVerificationThread() + 1810 5 net.nemetschek.vectorworks 0x00000001022e9b4e TLicenseVerifier::StaticStartVerificationThread(void*) + 14 6 net.nemetschek.vectorworks 0x00000001022f38c0 TThread::StartThread(void* (*)(void*), void*) + 160 7 libsystem_pthread.dylib 0x00007fff8621e268 _pthread_body + 131 8 libsystem_pthread.dylib 0x00007fff8621e1e5 _pthread_start + 176 9 libsystem_pthread.dylib 0x00007fff8621c41d thread_start + 13 Thread 4: 0 libsystem_kernel.dylib 0x00007fff912ce48a __semwait_signal + 10 1 libsystem_c.dylib 0x00007fff87c3ae50 usleep + 54 2 net.nemetschek.vectorworks.Renderworks 0x00000001120d6fe4 _melange_::GeSleep(int) + 132 (private_mac_pthread.cpp:1143) 3 net.nemetschek.vectorworks.Renderworks 0x00000001120d475b _melange_::IpKillThread::Main() + 75 (private_ge_sys_network.cpp:139) 4 net.nemetschek.vectorworks.Renderworks 0x00000001120d6a36 _melange_::BaseThread::Action() + 102 (private_mac_pthread.cpp:710) 5 net.nemetschek.vectorworks.Renderworks 0x00000001120d6815 _melange_::BeginThread(void*) + 21 (private_mac_pthread.cpp:363) 6 libsystem_pthread.dylib 0x00007fff8621e268 _pthread_body + 131 7 libsystem_pthread.dylib 0x00007fff8621e1e5 _pthread_start + 176 8 libsystem_pthread.dylib 0x00007fff8621c41d thread_start + 13 Thread 5: 0 libsystem_kernel.dylib 0x00007fff912c94de mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fff912c864f mach_msg + 55 2 com.apple.CoreFoundation 0x00007fff8bd9deb4 __CFRunLoopServiceMachPort + 212 3 com.apple.CoreFoundation 0x00007fff8bd9d37b __CFRunLoopRun + 1371 4 com.apple.CoreFoundation 0x00007fff8bd9cbd8 CFRunLoopRunSpecific + 296 5 com.apple.AppKit 0x00007fff89f4366b _NSEventThread + 137 6 libsystem_pthread.dylib 0x00007fff8621e268 _pthread_body + 131 7 libsystem_pthread.dylib 0x00007fff8621e1e5 _pthread_start + 176 8 libsystem_pthread.dylib 0x00007fff8621c41d thread_start + 13 Thread 6: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 7: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 8: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 9: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 10: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 11: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 12: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 13: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 14: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 15: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 16: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 17: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 18: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 19: 0 libsystem_kernel.dylib 0x00007fff912ce94a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff8621c40d start_wqthread + 13 Thread 20: Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000104947718 rbx: 0x00000000000002c0 rcx: 0x00000000000ed120 rdx: 0x00000000000ed11f rdi: 0x000000010a927b00 rsi: 0x0000000000000008 rbp: 0x00007fff5e08f780 rsp: 0x00007fff5e08f470 r8: 0x00007fd70cb2e800 r9: 0x000000000000ec00 r10: 0x000000003860add0 r11: 0x00000000b6523879 r12: 0x0000000000000000 r13: 0x0000610000cd1700 r14: 0x000000000000c6f9 r15: 0x0000610000cd1720 rip: 0x00000001036c2108 rfl: 0x0000000000010203 cr2: 0x0000000000000000 Logical CPU: 1 Error Code: 0x00000004 Trap Number: 14 Binary Images: 0x101b50000 - 0x104556ff7 +net.nemetschek.vectorworks (20.0.3 [257190] - 20.0.3) <32B1321E-9015-3067-9ED7-BC15C73565F4> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/Vectorworks 0x1054b0000 - 0x105a02ff7 +libdcu2d59.dylib (0) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libdcu2d59.dylib 0x105c72000 - 0x105e3bff7 +Python (3.3) <44DED1B9-A30A-9B29-97BD-038EBE557C6D> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/Python.framework/Versions/3.3/Python 0x105f54000 - 0x105f5aff7 +net.nemetschek.VWMM (1.0 - 1) <4244AC32-E6D4-308B-80C5-CCD3FE1E54DA> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/VWMM.framework/Versions/A/VWMM 0x105f67000 - 0x107179fff +libPDFNetC.dylib (6.2) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libPDFNetC.dylib 0x107698000 - 0x10769fff7 +libpsassemblyrep.dylib (0) <954E0774-C5CD-6DE3-22D7-70EE3DDE1337> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsassemblyrep.dylib 0x1076a7000 - 0x1077cdfff +libpsgeneric.dylib (0) <16434FC1-4AFE-2572-9466-0ED95AAC47D1> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsgeneric.dylib 0x107818000 - 0x107842fff +libpsiges.dylib (0) <31951056-17AE-A064-B182-9C8E600C1342> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsiges.dylib 0x10785b000 - 0x107892fff +libpsinterop.dylib (0) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsinterop.dylib 0x1078c7000 - 0x1078cbff7 +libpspropertiesbase.dylib (0) <1CB5C0EF-333F-CB24-AB99-70805878F9B9> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpspropertiesbase.dylib 0x1078d0000 - 0x10798ffff +libpsxlatorbase.dylib (0) <2C91607D-8A0F-C779-99D4-D4E81D4CBC7E> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsxlatorbase.dylib 0x1079db000 - 0x1079e0fff +libpspropertiesbrepimporter.dylib (0) <6DADA85A-7C08-35C5-9B70-A7ACD58C6DA3> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpspropertiesbrepimporter.dylib 0x1079e7000 - 0x107b4afff +libpsxcore.dylib (0) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsxcore.dylib 0x107ba0000 - 0x107da0ff7 +libpsxiges.dylib (0) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsxiges.dylib 0x107e11000 - 0x107e11ff5 +cl_kernels (???) <3826E8C5-2311-4421-825D-C7902CBD9E74> cl_kernels 0x107e16000 - 0x107e43ff7 +libpsxmil.dylib (0) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpsxmil.dylib 0x107e56000 - 0x107e56fef +cl_kernels (???) cl_kernels 0x107e5c000 - 0x10a6a9fff +libpskernel.dylib (0) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libpskernel.dylib 0x10a885000 - 0x10a889fff +libmessagehandler.dylib (0) <5E11829B-5D9A-2FE3-D117-B676A3826648> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libmessagehandler.dylib 0x10a894000 - 0x10a8d0fff +libHSIMac.dylib (1) <9C1CE2CB-5FFC-3286-90C7-A230BBAF3B34> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/MacOS/libHSIMac.dylib 0x10a9aa000 - 0x10a9afff7 libgermantok.dylib (17) <47EF3D93-B111-3218-AF60-E33F506D57E8> /usr/lib/libgermantok.dylib 0x10c255000 - 0x10c255ffe +cl_kernels (???) <612EB796-8349-4ECA-BD96-B991768CD1D6> cl_kernels 0x10c2ac000 - 0x10c2acfef +cl_kernels (???) cl_kernels 0x10c336000 - 0x10c336fe5 +cl_kernels (???) <81EA4B82-1AC8-4D36-89FF-9F50C19A6838> cl_kernels 0x10c33a000 - 0x10c33afe7 +cl_kernels (???) <5B9E3A8C-3C75-4763-8792-342E6AB1AE28> cl_kernels 0x10ec0a000 - 0x10ecf0fef unorm8_bgra.dylib (2.4.5) <7BFE1DA8-2BE4-3B4F-8A7F-F3D6D4D36ADA> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib 0x10fe72000 - 0x10fe77ff7 com.apple.URLMount.CIFSPlugin (7.0.0 - 7.0.0) /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb 0x10fe86000 - 0x10fe9ffff com.apple.SMBClient (3.0.0 - 3.0.0) <266D36D4-768D-3AE1-AF85-3C44A77E95F8> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient 0x10feaa000 - 0x10ff1bff7 com.apple.DCERPC (2.0 - 61) <3F2272F0-7D70-3243-9A39-EB824758FC32> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC 0x110556000 - 0x110598ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <27236284-3AE5-3C37-A3D3-32402F13647B> /Applications/Vectorworks 2015/*/CheckForUpdates 0x1105b9000 - 0x1105f3fff libiodbc.2.dylib (42.5) <26EFB7FB-1D37-39B9-86E4-6ED771BE01B0> /usr/lib/libiodbc.2.dylib 0x110602000 - 0x110604ff7 com.apple.textencoding.unicode (2.8 - 2.8) /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings 0x11091c000 - 0x11091dfe5 +cl_kernels (???) cl_kernels 0x110c18000 - 0x110e88fff +de.computerworks.vectorworks.CWLibraryUniversal1 (D20.0.3 R1 - 1.0) <2EE93114-4BE9-34C6-A766-5E9C2AC0B80D> /Applications/Vectorworks 2015/*/CWLibraryUniversal1 0x11104b000 - 0x111242ff7 +com.encina.gbXML (1.0) <83A0D5E9-1C64-3140-A35F-67AB77079372> /Applications/Vectorworks 2015/*/gbXML 0x1113e3000 - 0x111429fff +net.nemetschek.vectorworks.TesterModule (1.0) <1E500090-A39E-3FE3-B722-9BC31AC8E23E> /Applications/Vectorworks 2015/*/OnlineResources 0x111452000 - 0x1114a5fff +net.nemetschek.vectorworks. (1.0) <17610E10-DEED-3553-AF3D-70610D0380CF> /Applications/Vectorworks 2015/*/VS Shared Library 0x1114cd000 - 0x111b26fe7 +net.nemetschek.vectorworks.Support (1.0) /Applications/Vectorworks 2015/*/Support 0x111e02000 - 0x111e5bfff +net.nemetschek.vectorworks. (1.0) /Applications/Vectorworks 2015/*/Plug-In Support 0x111e88000 - 0x111ebeff7 libssl.0.9.8.dylib (52.20.2) /usr/lib/libssl.0.9.8.dylib 0x111f57000 - 0x1121c7fff +net.nemetschek.vectorworks.Renderworks (1.0) <7564E7BD-48E4-380D-B812-FDA939C60EBB> /Applications/Vectorworks 2015/*/Renderworks 0x112dcd000 - 0x112e0fff7 +net.nemetschek.vectorworks.VWLibrary (1.0) <7E288211-90BB-3E75-8E4A-68FF8C28E6CB> /Applications/Vectorworks 2015/*/VWLibrary 0x11306a000 - 0x113268fff +net.nemetschek.vectorworks.SpotlightModule (1.0) <00982D50-7174-3D23-A6C6-BFA2648E43CC> /Applications/Vectorworks 2015/*/Spotlight 0x113355000 - 0x1135e1ff7 +net.nemetschek.vectorworks.ArchitecturalObjects (1.0) /Applications/Vectorworks 2015/*/ArchitecturalObjects 0x1136b0000 - 0x113bf8ff7 +net.nemetschek.vectorworks.GIS (1.0) /Applications/Vectorworks 2015/*/GIS 0x113d96000 - 0x1141c8fff +net.nemetschek.vectorworks.LandscapeModule (1.0) <313F7D7E-E487-39E7-B48D-A6B36784CF7C> /Applications/Vectorworks 2015/*/Landscape 0x11438e000 - 0x114820fff +Raum CW (D20.0.3 R1 - 1.0) <59A40DD9-8854-376C-AE3D-BD508C775586> /Applications/Vectorworks 2015/*/Raum CW 0x114a86000 - 0x114f96ff7 +de.computerworks.vectorworks.Treppen (D20.0.3 R1 - 1.0) <68B663B6-06B8-347B-AEB1-C7909A4051BB> /Applications/Vectorworks 2015/*/Treppen 0x1152c7000 - 0x115338fff +net.nemetschek.vectorworks.Workspaces (1.0) /Applications/Vectorworks 2015/*/Workspaces 0x1155cf000 - 0x1156afff7 unorm8_rgba.dylib (2.4.5) <86BACF3B-4433-336D-BD90-C4A29060D703> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib 0x115745000 - 0x115745ff1 +cl_kernels (???) <5B91E69A-DB40-4961-8702-186E9150B7C8> cl_kernels 0x115787000 - 0x115787ffe +cl_kernels (???) <612EB796-8349-4ECA-BD96-B991768CD1D6> cl_kernels 0x1157a2000 - 0x11949afff +net.nemetschek.vectorworks. (1.0) <7AFDAF6D-60F4-37B3-BA95-6A1C5CD131BD> /Applications/Vectorworks 2015/*/DWG Library 0x11b64e000 - 0x11ba03fff +net.nemetschek.vectorworks.IFCLibrary (1.0) /Applications/Vectorworks 2015/*/IFCLibrary 0x11bb5e000 - 0x11bc88ff7 +net.nemetschek.vectorworks. (1.0) <1CB8D283-4FE5-37CB-8E1A-296DECE029FA> /Applications/Vectorworks 2015/*/3DS Library 0x11bd30000 - 0x11becdff7 +net.nemetschek.vectorworks.NotesManager (1.0) <82561AD0-0B2A-3C3B-B313-34522D72CF1F> /Applications/Vectorworks 2015/*/NotesManager 0x11cda4000 - 0x11ce0ffff +net.nemetschek.vectorworks.WebServices (1.0) <3FCA7312-C360-35F8-A9F9-EA3C66434165> /Applications/Vectorworks 2015/*/WebServices 0x11cfb4000 - 0x11cfbbfff com.apple.CacheDelete (1.0 - 1) /System/Library/PrivateFrameworks/CacheDelete.framework/CacheDelete 0x11d85b000 - 0x11d8a1fff +net.nemetschek.vectorworks.RenderSettings (1.0) <0B031FE2-154F-34A2-98ED-5DC4854FAED4> /Applications/Vectorworks 2015/*/RenderSettings 0x11e0ed000 - 0x11e10bff7 +DL100AXE8SharedExpat (101.0.4) <0F1ED7BD-2B86-3D9D-87C7-1728A0D29D22> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100AXE8SharedExpat.framework/Versions/A/DL100AXE8SharedExpat 0x11e224000 - 0x11e241fff +DL100BIB (101.0.5) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100BIB.framework/Versions/A/DL100BIB 0x11e3ad000 - 0x11e3d0ff7 +DL100BIBUtils (101.0.5) <368DB4F3-967E-3AE3-AA3A-3D3B7ABA35BA> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100BIBUtils.framework/Versions/A/DL100BIBUtils 0x11e40d000 - 0x11e446fff +DL100ARE (101.0.6) <5BEC3796-0737-37E3-9242-AA1EB1F00426> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100ARE.framework/Versions/A/DL100ARE 0x11f0e2000 - 0x11f14fff7 +com.adobe.ICUData (4.0 - 4.0) <563D24B9-1EC2-A553-E8BA-8D56FD7C3882> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData 0x11f416000 - 0x11f46cff7 +DL100AdobeXMP (101.0.2) <86EEDA4B-CDA3-3408-BD25-FEE03534ECCC> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100AdobeXMP.framework/Versions/A/DL100AdobeXMP 0x11fa1a000 - 0x11faccfef +com.adobe.ICUConverter (4.0 - 4.0) <6787A609-28A2-0813-16F8-4C410B9A01C2> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter 0x11fb1a000 - 0x11fb84fff +net.nemetschek.vectorworks.TextAlongPath (1.0) <504DFF64-1548-34BB-AC04-01DCE2648C10> /Applications/Vectorworks 2015/*/TextAlongPath 0x11fc01000 - 0x11fcfafff +net.nemetschek.vectorworks.PDFUtilityLib (1.0) <07ABD2AC-0DF1-323F-B3E2-6A0DED70B741> /Applications/Vectorworks 2015/*/PDFUtilityLib 0x11fd5b000 - 0x11fe74ff7 +DL100ACE (101.0.14) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100ACE.framework/Versions/A/DL100ACE 0x11feb1000 - 0x11ff38fff +DL100JP2KLib (101.0.3) <178F9E7D-F62D-38B9-BFB1-3F8436C5FDD7> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100JP2KLib.framework/Versions/A/DL100JP2KLib 0x1210c9000 - 0x121175fff ColorSyncDeprecated.dylib (442) <3518239D-60D5-39AF-A68C-E7B12564103C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib 0x1211c0000 - 0x1212eefff +net.nemetschek.vectorworks.VWGraphicsModule (1.0) /Applications/Vectorworks 2015/*/VWGraphicsModule 0x121438000 - 0x12143cffb libFontRegistryUI.dylib (134.1) <0E0D303E-2A48-340F-94A2-EEC3832E5895> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib 0x124f9a000 - 0x124f9bfff ATSHI.dylib (375.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib 0x12642f000 - 0x126553ff7 +net.nemetschek.vectorworks.ColorPalettes (1.0) <4A05367E-ED70-3E19-BB0A-A141B5C77D7B> /Applications/Vectorworks 2015/*/ColorPalettes 0x1267e4000 - 0x126827fff +net.nemetschek.vectorworks.Guides (1.0) <69583CC4-8617-32BB-83B9-C4B9ED72A605> /Applications/Vectorworks 2015/*/Guides 0x126d94000 - 0x126d97ff0 +cl_kernels (???) <0D1D844A-91F8-46B9-9D2E-B14C7A490600> cl_kernels 0x1298bc000 - 0x129e69fff +DL100AGM (101.0.23) <91FECB89-7118-3B7A-A56B-5BD1C7E9AC31> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100AGM.framework/Versions/A/DL100AGM 0x12ac7a000 - 0x12b1a5fff +com.datalogics.DL100CoolType (DL100CoolType 10.1.0.13 - 10.1.0.13) /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100CoolType.framework/Versions/A/DL100CoolType 0x12cfd3000 - 0x12d0f9ff7 +net.nemetschek.vectorworks.GeometryLib (1.0) <6DEFC787-B84B-37DF-8B54-8C8E7770510D> /Applications/Vectorworks 2015/*/GeometryLib 0x131169000 - 0x131383ff7 half_rgba.dylib (2.4.5) <7C56718A-3355-30A7-9639-43AC17BEBC3E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/half_rgba.dylib 0x134111000 - 0x13412cff3 com.apple.security.csparser (3.0 - 57031.20.26) <5AC778EB-AD12-377A-8C7A-8D3D4166CC73> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser 0x136d46000 - 0x13741eff7 +DL100PDFL (101.0.45) <2856B5F6-A0FE-3A50-9242-15AA84D969E8> /Applications/Vectorworks 2015/Vectorworks 2015.app/Contents/Frameworks/DL100PDFL.framework/Versions/A/DL100PDFL 0x123440000000 - 0x123440864ff7 com.apple.GeForceGLDriver (10.2.7 - 10.0.2) <0C5B7449-911C-35A0-8BC8-03FA1ADEB670> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver 0x7fff6b6ee000 - 0x7fff6b724837 dyld (353.2.1) <65DCCB06-339C-3E25-9702-600A28291D0E> /usr/lib/dyld 0x7fff84d29000 - 0x7fff8505afff com.apple.Foundation (6.9 - 1153.20) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff8505b000 - 0x7fff850affff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib 0x7fff850b0000 - 0x7fff851bfff3 com.apple.desktopservices (1.9.3 - 1.9.3) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff851c0000 - 0x7fff8524eff7 com.apple.CorePDF (4.0 - 4) <9CD7EC6D-3593-3D60-B04F-75F612CCB99A> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF 0x7fff8524f000 - 0x7fff8527afff com.apple.DictionaryServices (1.2 - 229) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff85519000 - 0x7fff85573ff7 com.apple.LanguageModeling (1.0 - 1) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff85691000 - 0x7fff85733fff com.apple.Bluetooth (4.3.4 - 4.3.4f4) /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x7fff85766000 - 0x7fff85878ff7 libvDSP.dylib (516) <151B3CCB-77D3-3715-A3D0-7C74CD5C7FFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff85879000 - 0x7fff8587bffb libCGXType.A.dylib (779.11) <51607E77-F183-3CC2-A78C-238AFBDF6262> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib 0x7fff85895000 - 0x7fff85907fff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff85925000 - 0x7fff85926ff3 libSystem.B.dylib (1213) /usr/lib/libSystem.B.dylib 0x7fff85927000 - 0x7fff85ba5fff com.apple.RawCamera.bundle (6.04 - 791) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x7fff85ba6000 - 0x7fff85ba6fff com.apple.quartzframework (1.5 - 1.5) <26C982A3-2FC3-3F50-B5F4-3C545C3BAC10> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz 0x7fff85ba7000 - 0x7fff85bb4fff libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib 0x7fff85bb5000 - 0x7fff85bbbfff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff85bbc000 - 0x7fff85ebeffb com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices 0x7fff85ebf000 - 0x7fff85ee6fff com.apple.shortcut (2.14 - 2.14) <0E9228EC-E688-3E83-9516-5211FFEA923E> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut 0x7fff85ee7000 - 0x7fff8621aff7 libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib 0x7fff8621b000 - 0x7fff86224fff libsystem_pthread.dylib (105.10.1) <3103AA7F-3BAE-3673-9649-47FFD7E15C97> /usr/lib/system/libsystem_pthread.dylib 0x7fff86225000 - 0x7fff86293ffb com.apple.Heimdal (4.0 - 2.0) <7697A837-98B8-3BDB-A7D2-8ED4C9ABC510> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff86294000 - 0x7fff8629ffdb com.apple.AppleFSCompression (68.1.1 - 1.0) /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fff862a0000 - 0x7fff864e5ff7 com.apple.AddressBook.framework (9.0 - 1579) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook 0x7fff864e6000 - 0x7fff864f3ff3 com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0x7fff864f4000 - 0x7fff864f5ff7 libodfde.dylib (22) <52D0ABCD-F464-362C-86EA-ACA10993F556> /usr/lib/libodfde.dylib 0x7fff864f6000 - 0x7fff868cdfe7 com.apple.CoreAUC (211.1.0 - 211.1.0) <12645629-E065-388E-A6B5-094A240578CE> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC 0x7fff868ce000 - 0x7fff869e7ffb com.apple.CoreText (352.0 - 454.6) /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff869e8000 - 0x7fff86b2fffb com.apple.WebKitLegacy (10600 - 10600.5.17) /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy 0x7fff86b30000 - 0x7fff86b9cfff com.apple.framework.CoreWLAN (5.0 - 500.35.2) <5E228544-77A9-3AA5-8355-E8F6626F50E7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x7fff86b9d000 - 0x7fff86be8fff com.apple.CloudDocs (1.0 - 321.6) <4C54EDB7-4377-3722-8C47-F3C3D260FCBA> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs 0x7fff86c84000 - 0x7fff86ca8fef libJPEG.dylib (1237) <6DB10054-5C64-32FB-83FD-E102A8F73258> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff86d47000 - 0x7fff870b2fff com.apple.VideoToolbox (1.0 - 1562.235) <0E996B8C-BE1C-3749-ACCA-DACBC89AFABB> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x7fff870b3000 - 0x7fff870b3ff7 liblaunch.dylib (559.20.9) /usr/lib/system/liblaunch.dylib 0x7fff870b4000 - 0x7fff870bbfff com.apple.network.statistics.framework (1.2 - 1) <61B311D1-7F15-35B3-80D4-99B8BE90ACD9> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics 0x7fff870bc000 - 0x7fff8713afff com.apple.CoreServices.OSServices (640.4 - 640.4) <20121A5E-7AB5-3624-8CF0-3562F97C8A95> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff8713b000 - 0x7fff8713bfff com.apple.Accelerate (1.10 - Accelerate 1.10) <2C8AF258-4F11-3BEC-A826-22D7199B3975> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff8713c000 - 0x7fff8714bff7 com.apple.ToneLibrary (1.0 - 1) <179C7D61-CB88-3CE3-9F06-4D60D13D616C> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary 0x7fff87159000 - 0x7fff8715dfff libspindump.dylib (182.4) <929670EB-4963-3496-AD24-8B50E388803C> /usr/lib/libspindump.dylib 0x7fff8715e000 - 0x7fff87165ff7 libcompiler_rt.dylib (35) /usr/lib/system/libcompiler_rt.dylib 0x7fff87166000 - 0x7fff871acff7 libauto.dylib (186) /usr/lib/libauto.dylib 0x7fff871ad000 - 0x7fff871b4fff com.apple.NetFS (6.0 - 4.0) <1581D25F-CC07-39B0-90E8-5D4F3CF84EBA> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff871b5000 - 0x7fff8721aff7 com.apple.ids (10.0 - 1000) <42C61956-F016-315A-ADD3-3CA37EE99DD7> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS 0x7fff8721b000 - 0x7fff8721cff7 com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff8721d000 - 0x7fff87231feb libCGInterfaces.dylib (294.1) <390D4B3F-B738-3D33-BEDB-07E3F0F6B42C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib 0x7fff87232000 - 0x7fff8742c46f libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib 0x7fff8742d000 - 0x7fff87458ff3 libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib 0x7fff87472000 - 0x7fff87474ff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib 0x7fff87475000 - 0x7fff87479fff com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff8747a000 - 0x7fff874eeffb com.apple.securityfoundation (6.0 - 55126) <42589E18-D38C-3E25-B638-6E29740C224C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff874ef000 - 0x7fff87509ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff8750a000 - 0x7fff87535fff libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib 0x7fff87536000 - 0x7fff87585ff7 libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib 0x7fff87586000 - 0x7fff875d5ff7 com.apple.opencl (2.4.2 - 2.4.2) <4A9574ED-15CF-3EBB-B4C0-D30F644D6C74> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff875d6000 - 0x7fff87623ff7 com.apple.print.framework.PrintCore (10.3 - 451.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff87624000 - 0x7fff8763efff com.apple.AppleVPAFramework (1.4.4 - 1.4.4) <5C37DBD3-EB91-3A58-BD2F-E0CD533DE467> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA 0x7fff8763f000 - 0x7fff87647fff libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib 0x7fff876e2000 - 0x7fff8770bffb libxslt.1.dylib (13) /usr/lib/libxslt.1.dylib 0x7fff8770c000 - 0x7fff8770efff libCVMSPluginSupport.dylib (11.1.2) <6EFEC4A6-2EAC-3C27-820E-C28BE71B9FCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff8770f000 - 0x7fff87787ff7 com.apple.SystemConfiguration (1.14 - 1.14) <06A8405D-53BA-30A9-BA8A-222099176091> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff87788000 - 0x7fff87809ff7 com.apple.CoreUtils (1.1 - 110.1) /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0x7fff8781d000 - 0x7fff87823ff7 com.apple.XPCService (2.0 - 1) /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService 0x7fff87824000 - 0x7fff87864ff7 libGLImage.dylib (11.1.2) <260A4BF3-DC45-369C-A0CD-B667F9D17179> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff87865000 - 0x7fff87b80fcf com.apple.vImage (8.0 - 8.0) <1183FE6A-FDB6-3B3B-928D-50C7909F2308> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff87b81000 - 0x7fff87b82fff liblangid.dylib (117) /usr/lib/liblangid.dylib 0x7fff87b83000 - 0x7fff87bbbfff libsystem_network.dylib (412.20.3) <589A5F67-BE2A-3245-A181-0ECC9B53EB00> /usr/lib/system/libsystem_network.dylib 0x7fff87bbc000 - 0x7fff87c48ff7 libsystem_c.dylib (1044.10.1) <86FBED7A-F2C8-3591-AD6F-486DD57E6B6A> /usr/lib/system/libsystem_c.dylib 0x7fff87c5f000 - 0x7fff87d0efe7 libvMisc.dylib (516) <6739E390-46E7-3BFA-9B69-B278562326E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff87d0f000 - 0x7fff87d24ff7 com.apple.AppContainer (4.0 - 238.20.2) <2AA2EF49-9F38-31F6-8B08-8CC7C26F57F3> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer 0x7fff87d25000 - 0x7fff87de0ff7 com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording 0x7fff87de1000 - 0x7fff87de3fff libRadiance.dylib (1237) <9B048776-53BB-3947-8ECE-9DDA804C86B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff87de4000 - 0x7fff87dffff7 com.apple.aps.framework (4.0 - 4.0) <5F4CEDD6-C7AD-3026-A5F3-9146F08F23D2> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService 0x7fff87e00000 - 0x7fff87f67ffb com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff8809c000 - 0x7fff8809eff7 com.apple.diagnosticlogcollection (10.0 - 1000) /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection 0x7fff8809f000 - 0x7fff88128ff7 com.apple.CoreSymbolication (3.1 - 57020.1) <85707039-0C8A-3409-B0B5-153431CC1841> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff88129000 - 0x7fff88149fff com.apple.IconServices (47.1 - 47.1) /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff8814d000 - 0x7fff8815efff libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib 0x7fff8815f000 - 0x7fff8858ffff com.apple.vision.FaceCore (3.1.6 - 3.1.6) /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff88590000 - 0x7fff88aa5ffb com.apple.JavaScriptCore (10600 - 10600.5.10) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff88aa6000 - 0x7fff88aacfff libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib 0x7fff88b2f000 - 0x7fff88b34ffb libheimdal-asn1.dylib (398.10.1) /usr/lib/libheimdal-asn1.dylib 0x7fff88b35000 - 0x7fff88b4eff7 com.apple.CFOpenDirectory (10.10 - 187) <790ED527-EFD2-3EA6-8C97-A8C04E96EBA7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff88f43000 - 0x7fff88f5cffb com.apple.openscripting (1.4 - 162.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff88f5d000 - 0x7fff88f5dfff com.apple.CoreServices (62 - 62) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff88f5e000 - 0x7fff88fbdfff com.apple.AE (681.2 - 681.2) <181B3B06-2DC6-3E4D-B44A-2551C5E9CF6F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff88fbe000 - 0x7fff88fc7fff libGFXShared.dylib (11.1.2) <0BAF2EA8-3BC4-3BF4-ABB6-A6E0A1F3F6A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff88fc8000 - 0x7fff8906ffff com.apple.PDFKit (3.1 - 3.1) <717B6DB9-4C81-3326-AFB7-6B003FBF1311> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit 0x7fff89070000 - 0x7fff89094ff7 com.apple.Sharing (328.16 - 328.16) /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff890bb000 - 0x7fff890c6fff com.apple.CommerceCore (1.0 - 376.24) <1B2B5206-43B6-3CA4-B057-8A7252CE6902> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore 0x7fff890c7000 - 0x7fff890e1ff7 liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib 0x7fff893fe000 - 0x7fff8967dff7 com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff897e6000 - 0x7fff89840fff com.apple.Suggestions (4.0 - 165) <34A8FB72-F663-3085-B4D0-6982B0BDCF21> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions 0x7fff89841000 - 0x7fff89842ff7 com.apple.AddressBook.ContactsData (9.0 - 1579) /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData 0x7fff89843000 - 0x7fff8984aff7 libCGCMS.A.dylib (779.11) <5D33FF8C-AC74-3B7B-A602-4AA470FEAF79> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib 0x7fff8984b000 - 0x7fff8984dfff com.apple.ExceptionHandling (1.5 - 10) /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling 0x7fff8984e000 - 0x7fff89850fff com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin 0x7fff89851000 - 0x7fff8988eff3 com.apple.bom (14.0 - 193.6) <3CE5593D-DB28-3BFD-943E-6261006FA292> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x7fff8988f000 - 0x7fff899c1ff7 com.apple.MediaControlSender (2.0 - 215.18) <86E901A7-64C3-3D2C-BBD4-E385405831D3> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender 0x7fff899c2000 - 0x7fff899e3fff com.apple.framework.Apple80211 (10.3 - 1030.71.6) /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x7fff899e4000 - 0x7fff89a08ff7 com.apple.quartzfilters (1.10.0 - 1.10.0) <1AE50F4A-0098-34E7-B24D-DF7CB94073CE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters 0x7fff89a09000 - 0x7fff89ac9ff7 com.apple.backup.framework (1.6.4 - 1.6.4) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff89aca000 - 0x7fff89accfff libsystem_sandbox.dylib (358.20.5) <4CF77128-6BE0-3958-B646-707FA9CE61B2> /usr/lib/system/libsystem_sandbox.dylib 0x7fff89acd000 - 0x7fff89b37fff com.apple.imfoundation (10.0 - 1000) /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation 0x7fff89b38000 - 0x7fff89b89fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff89bb2000 - 0x7fff89bbafff libMatch.1.dylib (24) /usr/lib/libMatch.1.dylib 0x7fff89bbb000 - 0x7fff89bd9ff7 com.apple.addressbook.vCard (9.0 - 1579) /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard 0x7fff89be9000 - 0x7fff89cdbfff libxml2.2.dylib (26) /usr/lib/libxml2.2.dylib 0x7fff89cdc000 - 0x7fff89ce1ff7 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib 0x7fff89ce2000 - 0x7fff89d12ff3 com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <3E51287C-E97D-3886-BE88-8F6872400876> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD 0x7fff89d13000 - 0x7fff89d1eff7 com.apple.DirectoryService.Framework (10.10 - 187) <85675744-B77D-37ED-805B-4BD0DD20845D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService 0x7fff89d1f000 - 0x7fff89db6fff com.apple.CoreMedia (1.0 - 1562.235) <21EB4AB6-2DBC-326B-B17E-E88BAA9E9200> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x7fff89dea000 - 0x7fff8a96bff7 com.apple.AppKit (6.9 - 1347.57) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff8a96c000 - 0x7fff8a99cfff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib 0x7fff8a99d000 - 0x7fff8a9a6fff com.apple.DisplayServicesFW (2.9 - 372.1) <30E61754-D83C-330A-AE60-533F27BEBFF5> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices 0x7fff8aa04000 - 0x7fff8aa0cff7 com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice 0x7fff8aa46000 - 0x7fff8aa60ff7 libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib 0x7fff8aa61000 - 0x7fff8aa63fff com.apple.SecCodeWrapper (4.0 - 238.20.2) /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper 0x7fff8aa64000 - 0x7fff8aa77ff7 com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x7fff8aa8e000 - 0x7fff8aa9bff7 libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib 0x7fff8aaff000 - 0x7fff8aafffff libOpenScriptingUtil.dylib (162.1) /usr/lib/libOpenScriptingUtil.dylib 0x7fff8ab00000 - 0x7fff8ab0aff7 com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff8abb0000 - 0x7fff8abb3fff libCGXCoreImage.A.dylib (779.11) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib 0x7fff8abb4000 - 0x7fff8abbcfff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib 0x7fff8abbd000 - 0x7fff8abbefff com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fff8ac4c000 - 0x7fff8ad92fef libsqlite3.dylib (168) <8B78BED1-7B9B-3943-80DC-0871015AEAC4> /usr/lib/libsqlite3.dylib 0x7fff8ad93000 - 0x7fff8adb2fff com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet 0x7fff8adb3000 - 0x7fff8ade3fff com.apple.GSS (4.0 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff8ade4000 - 0x7fff8ae68fff com.apple.PerformanceAnalysis (1.0 - 1) <599AED3E-B689-3C40-8B91-93AD36C97658> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff8ae76000 - 0x7fff8ae79fff com.apple.IOSurface (97.4 - 97.4) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff8aeaa000 - 0x7fff8aec1ff7 libLinearAlgebra.dylib (1128) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff8af1c000 - 0x7fff8af28ff7 com.apple.commonutilities (8.0 - 900) /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities 0x7fff8af29000 - 0x7fff8af56fff com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff8af57000 - 0x7fff8af57fff com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff8af58000 - 0x7fff8b0b9fff com.apple.avfoundation (2.0 - 889.210) <0CFF0D47-7C6B-388E-87BD-404F43A6B1E0> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation 0x7fff8b1bb000 - 0x7fff8b4e6ff7 com.apple.FinderKit (1.3.4 - 1.3.4) <3922DF95-2F38-3CAA-A7E7-B1A691261591> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit 0x7fff8b4e7000 - 0x7fff8b528fff libGLU.dylib (11.1.2) <4C54F0D1-2ADC-38A0-92D1-F479E9B99355> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff8b529000 - 0x7fff8b66dff7 com.apple.QTKit (7.7.3 - 2890) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit 0x7fff8b66e000 - 0x7fff8b792ff7 com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff8b793000 - 0x7fff8b79efff libcommonCrypto.dylib (60061) /usr/lib/system/libcommonCrypto.dylib 0x7fff8b79f000 - 0x7fff8b7c7fff libRIP.A.dylib (779.11) <88434DA0-B6B8-304A-9DC0-41D3947E8734> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x7fff8b7c8000 - 0x7fff8bcb8fff com.apple.MediaToolbox (1.0 - 1562.235) <9813E9A6-5BD6-3E56-9D20-0023703D5096> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x7fff8bcb9000 - 0x7fff8bd2affb com.apple.ApplicationServices.ATS (360 - 375.2) <2338AF23-528F-359A-847F-8B04E49E2B84> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff8bd2b000 - 0x7fff8c0c3ff7 com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff8c0d3000 - 0x7fff8c120ff3 com.apple.CoreMediaIO (601.0 - 4760) /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO 0x7fff8c195000 - 0x7fff8c3ffff7 com.apple.security (7.0 - 57031.20.26) <6568520A-587D-3167-BB79-60CE6FEADC64> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff8c400000 - 0x7fff8c44dfff com.apple.ImageCaptureCore (6.3 - 6.3) <44B6E670-16ED-3C81-9E8D-34543CD71273> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore 0x7fff8c44e000 - 0x7fff8c4dfff7 libCoreStorage.dylib (471.20.7) /usr/lib/libCoreStorage.dylib 0x7fff8c4e0000 - 0x7fff8c5d2ff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib 0x7fff8c5d3000 - 0x7fff8c61fff7 libcups.2.dylib (408.2) /usr/lib/libcups.2.dylib 0x7fff8c620000 - 0x7fff8c643ff7 com.apple.idsfoundation (10.0 - 1000) <2395F969-DB5F-3D41-BA52-31FEE83E0719> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation 0x7fff8c64e000 - 0x7fff8c663fff com.apple.ToneKit (1.0 - 1) <25D0FF56-B802-359D-9CA1-D530F4890D87> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit 0x7fff8c664000 - 0x7fff8c66bff7 com.apple.phonenumbers (1.1.1 - 105) /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers 0x7fff8c66c000 - 0x7fff8c81bfff GLEngine (11.1.2) <68FDFD73-F15C-3460-9984-10F5DEF79907> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7fff8c81c000 - 0x7fff8c81eff7 libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib 0x7fff8c81f000 - 0x7fff8c82aff7 libcsfde.dylib (471.20.7) <44E51549-CECC-3C7B-867B-01901CA9C756> /usr/lib/libcsfde.dylib 0x7fff8c82b000 - 0x7fff8c8a1fe7 libcorecrypto.dylib (233.1.2) /usr/lib/system/libcorecrypto.dylib 0x7fff8c8a2000 - 0x7fff8c8c7fff libPng.dylib (1237) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff8d226000 - 0x7fff8d261fff com.apple.Symbolication (1.4 - 56045) /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x7fff8d262000 - 0x7fff8d266fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib 0x7fff8d267000 - 0x7fff8d2d3ff3 com.apple.MMCS (1.3 - 327.5) /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS 0x7fff8d2e8000 - 0x7fff8d2e8ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib 0x7fff8d2e9000 - 0x7fff8d321fff com.apple.RemoteViewServices (2.0 - 99) /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff8d322000 - 0x7fff8d325ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo 0x7fff8d38a000 - 0x7fff8d659ff3 com.apple.CoreImage (10.3.4) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff8d65a000 - 0x7fff8d65fff7 com.apple.MediaAccessibility (1.0 - 61) <00A3E0B6-79AC-387E-B282-AADFBD5722F6> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility 0x7fff8d660000 - 0x7fff8d754fff libFontParser.dylib (134.2) <9F57B025-AB9C-31DD-9D54-2D7AB1298885> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff8d755000 - 0x7fff8d756ff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib 0x7fff8d757000 - 0x7fff8d761fff com.apple.IntlPreferences (2.0 - 150.1) /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences 0x7fff8d764000 - 0x7fff8d781ffb libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib 0x7fff8d782000 - 0x7fff8d818ff7 com.apple.cloudkit.CloudKit (283.67.2 - 283.67.2) <79F5AD38-61D5-30E6-96DC-974351D4195B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit 0x7fff8d832000 - 0x7fff8d86bff3 com.apple.datadetectors (5.0 - 286.13) /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors 0x7fff8d86c000 - 0x7fff8d874ff3 com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff8d875000 - 0x7fff8d8c1fff com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation 0x7fff8d8e0000 - 0x7fff8d8e3ff7 libdyld.dylib (353.2.1) <9EACCA38-291D-38CC-811F-7E9D1451E2D3> /usr/lib/system/libdyld.dylib 0x7fff8d8e4000 - 0x7fff8d8e9ff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib 0x7fff8d950000 - 0x7fff8d989fff com.apple.AirPlaySupport (2.0 - 215.18) <6AF8E973-3643-3FEE-AA8F-541B9F093EEE> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport 0x7fff8d98a000 - 0x7fff8d9adff7 com.apple.framework.familycontrols (4.1 - 410) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls 0x7fff8d9ae000 - 0x7fff8da84ff3 com.apple.DiskImagesFramework (10.10.1 - 396) <1149D3E1-CC6C-3177-916D-2BE066DC9344> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages 0x7fff8e0ef000 - 0x7fff8e117fff libsystem_info.dylib (459.20.1) /usr/lib/system/libsystem_info.dylib 0x7fff8e118000 - 0x7fff8e123ff7 com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff8e124000 - 0x7fff8e12cff7 com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP 0x7fff8e228000 - 0x7fff8e2c6fff com.apple.Metadata (10.7.0 - 917.35) <8CBD1D32-4F4B-3F9A-AC65-76F2B5376FBF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff8e2c7000 - 0x7fff8e2d4ff7 com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x7fff8e2d5000 - 0x7fff8e485ff3 com.apple.QuartzCore (1.10 - 361.18) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff8e486000 - 0x7fff8e693ff3 com.apple.CFNetwork (720.3.13 - 720.3.13) <69E15385-5784-3912-88F6-03B16F1C1A5C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff8e694000 - 0x7fff8e6a5fff libsystem_coretls.dylib (35.20.2) <6084A531-2523-39F8-B030-811FA1A32FB5> /usr/lib/system/libsystem_coretls.dylib 0x7fff8e6b1000 - 0x7fff8e6b1fff com.apple.Cocoa (6.8 - 21) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff8e6de000 - 0x7fff8e6e0fff libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib 0x7fff8e6e1000 - 0x7fff8e710fff com.apple.securityinterface (10.0 - 55058) <21F38170-2D3D-3FA2-B0EC-379482AFA5E4> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface 0x7fff8e711000 - 0x7fff8e712fff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff8e713000 - 0x7fff8e71fff7 libGPUSupportMercury.dylib (11.1.2) <55BFDDBD-C196-3D24-A7DA-905A6A722DAC> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib 0x7fff8e720000 - 0x7fff8e74fff7 com.apple.CoreServicesInternal (221.7.2 - 221.7.2) /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fff8e750000 - 0x7fff8f712ffb com.apple.WebCore (10600
  16. Offset either side of a centre line. e.g. draw a centre line of a road, offset required distance to produce a closed polyline representing a road. I can't find this option in the current toolbox. If I have missed it please let me know.
  17. A number of VW users in my office are reporting problems exporting to DWG, crashing on export. The same file if saved back to 2014 exports to DWG with no problem. We have tried publishing to dwg but the problem persists. The drawing does does have a couple of image fills and uses a sketch style which shouldn't be a problem as they export fine from VW2014. Any ideas?
  18. Thanks for the reply. I'll carry on as before for the time being. Thanks again.
  19. I use the property line to produce land use budgets for Master Plans. It would be useful if the Number field could become a calculation field in which the Area Units (hectares) could be multiplied by a number (housing density, say 30) to display the total number of dwellings in a given area. In other words have the same functionality of a database field in a worksheet. Also the Area units always display hectares in full an abbreviation option to (ha) would be fantastic.
  20. Pat That sees really useful, I will give it a try. I'd like to thank you for all your help. Cheers.
  21. You are quite right and I thought that should work. I just found to that none of the circles are exactly the same size. Object info palette said 12m. but in fact it was 12.0002m. same with all the circles. Down to the document precision settings. Thanks again for making me think.
  22. Pat Stanford posted a script for selecting lines of similar length back in 2012. Can this be modified to select circles of same radius? http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=166219Post166219 Procedure SelectSameLengthLines; {If the first selected object in the drawing is a line} {this script gets the length of that line and selects all} {other lines in the drawing that have the same length.} {February 13, 2012} {? 2012, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} Var H1 :Handle; OLength :Real; Procedure DoIt(H2:Handle); Begin If HLength(H2)=OLength then SetSelect(H2); End; Begin If GetType(FSActLayer)=2 then Begin OLength:=HLength(FSActLayer); ForEachObject(DoIt,((T=LINE))); End Else AlrtDialog('First Selected Object Must Be A Line.'); End; Run(SelectSameLengthLines);
  23. I want to select all circles of the same size on a plan and replace with a symbol which will be the same radius. The select similar tool does not have radius as an option and custom selection menu does not have this option. If I can select all circles in one hit and replace with a scaled symbol to match the circle radius that would be even better. Any ideas?
  24. I wish that you the Property Line tool would enable you to display the metric area dimensions as (ha) rather than (hectares). Or at least the option to customise. I use the property line tool to create land budget plans and a figure with 2 decimal places plus hectares will not often fit within the boundary. It would be useful to change the text size for different fields.
  25. Dexie
    GIS annotation
    This might help. Back in 2004 I wanted the insert the record data attached to 2D loci imported as a shape file. This script was posted. You had to attach the script to a tool. It worked really well. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=17128&Number=77062#Post77062
