sc.78
    8
Everything posted by sc.78
  1. Hi Antonio, I tried your suggestion, end changing the "name" with a "string" one, whit "column2" worked (I have problem uploading picture now but I'll try again later) and If I use the "get symbol from folder" node, even if set a column style, it does not work, (at least I was not able, may be I'm missing something). My goal now is to be able to insert a "structural member" object, not the "column" object.
  2. Hi Antonio, just seen your reply. tomorrow I'll try. Thanks a lot Simone
  3. Hi Tom, thanks, I will ask Juan (thanks for the contact). By the way, meanwhile I try to get the access can you tell me if the course has the same content of the monday-webinar by Sarah Barrett or it is a dedicated course of 6 or + hours?
  4. I don't know what kind of permission are required. Are you able to access it?
  5. Hi Tom, yes, I have an account for vw university and forum, but it keeps saying access restricted.
  6. Hy everybody I don't know if this is the right place for this question, in case of I apologize. I was looking for some marionette advanced training course or similar, and I found this: https://university.vectorworks.net/enrol/index.php?id=1659 whit restricted access, and no information how to access, if it's still available or not. May be it's an old page, does anyone knows anything about it?
  7. Hi Pat, thanks for your help. I tried to follow your instruction. I inserted a column, named it Prova, added the create custm obj node, set name of the object with a name node, integer for the angle, but when I run it it create copy of the column in the same place of the column itself instead of copying it in each Locus point created inside the polyline. I probably forget to set something nu I cant find out what
  8. Hi everybody, I have a litle experience with vectoreworks and totally new at marionette. For my next new job I will be in charge of choosing the right BIM solution, and after 10 years of tears with Revit (which is a good software altough) I started using VW again after years, and I would like to propose it as BIM solution in my office. I finished the beginning and intermediate course of VW university and now I wanted to verify and understand the potential of marionette comapred to dynamobim. I just finished the 1st monday webinar, and I was courious if there is a way to automatically place a structural member (not an extrusion, the structural column object) at locus point as created inside the polyline at the end of the 1st monday webinar. I apologize if I make a stupid question but I did not find anything in the forum or in the web. Any suggestion?
