Cadfael
    3
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Designer
  • Location
    Pottstown, PA
  1. As for OS9: I installed it on a used Power Mac 9500/132 with 128Mgs of RAM. The replacement hard drives (non-Apple) were partitioned into four volumes and only one would accept OS9. I can't say that I've had any problems, but as a designer my files have not yet exceeded 1.2Mgs. The only problem I do have is with the speed of Appleworks 6(!). So don't be discouraged. OS 9 was really intended for the G3's and G4's, not the older machine I have. ------------------
  2. In working with Shrub #1, I find that although I place it in the correct place in plan projection, it does not appear in that location in right or left isometric views. What can I do to correct this?
  3. When I try to draw a cabinet face frame with openings for the doors by using the rectangle tool (creating the face and punching the holes with other rectagles for the door openings) using the "clip surface" command, I get extra lines centered above & below the openings after I follow up with the extrude command. They show when the drawing is rendered as well. Is there a way to get rid of these lines? Or, do I need to use a different approach? ------------------
