Eureka.
Thanks a lot for the screencast! of course I made the wrong edits to the txt-file. π Regarding accessability: Makes sense to have that info in the user app data. But since I can't see the file location in the status bar in your video, it took a bit of searching for the right location to copy the file to. For anyone having the same problem (Windows):
copy from...
C:\Program Files\Vectorworks 2022\Plug-Ins\connectCAD_Data
to...
C:\Users\UserName\AppData\Roaming\Nemetschek\Vectorworks\2022\Plug-Ins\connectCAD_Data
Might be worth putting this kind of info in the actual help section of Vectorworks? π
Okay, you losing me again, I am very sorry (and feel a bit dumb). π
1. the device_labels are symbols used inside devices
2. devices are (intelligent?) objects. or rather there is one object "device" which all used devices are based on
3. storing a device as a symbol to the library does not mean that I can change the library symbol to update all devices in the drawing
4. for global changes I would have to add symbols inside devices (other then device_labels), but these would apply to all devices
reg. 3. why would I then want to store a device as a symbol in the library, if I don't have a central location to edit?
plus, when I edit the newly created "device symbol" in the ressource manager it turns into a group (light blue text)
(on the left is a device created with the "device builder", which you are saying is not a symbol but a device object.)
reg. 4. I don't understand how I can do that. plus, when I say all devices I should have correctly said "all devices of the same make and model". maybe I forgot to add an output to the above Crestron NVX and want to add it later, I was hoping to just update the device definition in the ressource manager and be done with it. but you are saying that that doesn't work and I have to use the Pick Up tool instead. (having to possibly select 1000 blocks spread out over the schematic depending on the device)?
thanks so much for your patience and help
