jbin
    8
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Metalsmith
  • Homepage
    mokume-gane.com
  1. When you generate a lofted surface (no rails) Vctorworks creates a NURBS curve that "fits" to the selected curves. Sometimes it generates wild curves that dont seem to be a fit to the spacing and relationship of the curves that it is connecting. So it would be nice to beable to go in and edit this curve like you can with the Extrude Along Path tool or when editing boolian solids
  2. quote: Originally posted by propstuff: It just occured to me Jim: If you take the grain that you have punched out, and section it "horizontally" flat along it's length you will now be able to extract a planar curve of the grain shape that can be used in a Revolve. That could be added back to the bottom half for use later. 'Might work OK. BTW, how long did the Tea Pot take to make? cheers, N. Nicholas, thanks for your help with this. I will try that as well. The lofting is working but it is taking a lot of fiddling around to make it the "right" shape. The teapot was a about a three month long project. It was very labor intensive as the sheet for it had to be hand forged before I could make the teapot from it.
  3. quote: Originally posted by Kaare Baekgaard: If the corn decorations are all identical, you might consider using symbols. (Unknown to some, symbols can take part in solid operations.) Nice item. what is it? I am not certain what you mean about how I would use a symbol in this instance. The item is a transition piece from bowl to stem for a chalice.
  4. quote: Originally posted by propstuff: You have some very nice things there Jim. Beautiful. I have made a model of a standard "American" Brilliant Cut diamond. If you want a copy let me know. Good luck with the wheat. N. Thanks for your comments, Sorry about the delay in responding but I have been in New York for a conference the past few days. I would love a brilliant cut model.
  5. quote: Originally posted by propstuff: quote: I cannot figure out how to erect an axis perpendicular to the curve face as you can see the form that the grains are on is a complex surface. Is there a way to erect an axis perpendicular to a {complex curved} surface? OK, then, Well I'd be interested in an answer to that question, but in the meantime...... The "Revolve" command requires a Planar rail curve (see manual) . The revolve also has a tendancy to produce anomolies at the centre of irregular surfaces unless you're carefull with the profile and the axis. The Loft technique I described will work for you (but with a little more fiddling than you want). N. Thanks for your help on this I will try the lofting. Jim
  6. quote: Originally posted by Kaare Baekgaard: You can use the 'Revolve with rail* tool. I thought of that but I cannot figure out how to erect an axis perpendicular to the curve face as you can see the form that the grains are on is a complex surface. Is there a way to erect an axis perpendicular to a surface?
  7. So is there another way I can create this shape? It is punched from a curved nurbs surface using the project tool then I shelled it to give it thickness. Jim
  8. Hello, I am trying to create a rounded face on a nurbs shelled surface. I have tried filleting the edge but it will not give me enough rounding, it leaves a flat still on the top of the solid. How can I round this surface so that it is a smooth transition from the base to the top center?
