Truss Breakout Dissconnecting.mov
Cable Path Issue.mov
Hello,
I am starting to play around with the '22 cable tool in VWX. I found the video from VWX on vimeo that is 3 hours long and digs into the tool, great video!
That being said, I am having issues with the cable following geometry of truss. I know I can make the cable path longer, but in the summit video the presenter has a cable path to the truss and then without needing a further cable path the soca cable follows the geometry of the truss to get to the breakouts. I am attaching a video of the issue i'm having. The breakouts here are a part of the truss system as far as I can tell.
A second issue (possibly a bug) I am adding in a second video is in regards to moving the position of the truss once the cable is attached to the breakout. In this instance when I move the truss object which includes the breakout that is a part of the trust system it disconnects from the soca line it was connected it to. If I move just the break out the soca remains connected. Kind of a bummer that moving the truss that the soca wouldn't stay connected and automatically update.
Any help/advice on both issues is greatly appreciated, let me know if I did not explain well enough the problems I am having and thank you!
