Scott Waller
    8
Everything posted by Scott Waller
  1. Hi There, I'm having a weird thing where only certain signal types are showing on the Sheet Layer. They appear on the design layer, but when I create a viewport for my sheet layer, only some of the signals are showing. Thanks in advance. Scott
  2. OK, yes Conrad you are correct, that's exactly what I would do. Thanks for the fix.
  3. here is the original file. Line Drawing AAT ACT [REV A].vwx
  4. Also I seem to have any of the options when I right click on a device?
  5. Hey guys, yes did that. I am only running VW 2020 on my machine. Just did it again and got the same result. It seems that the new version doesn't like the classic connectors.
  6. OK, just did another test. I use 'classic' connectors and that seems to be the issue. When I put them back to the default connector it connects. Any ideas? Cheers
  7. Hi There, I'm having an issue with devices I have copied from CC 2019 to VW 2020. All devices seemed to copy and past correctly however, when I try an connect the devices to each other it just says 'Disconnected' I have created a simple 1in 1out device from scratch and they seem to work fine. I would really not like to re-create all my devices. Thanks
