RubenH
Distributor
    506
Everything posted by RubenH
  1. Are you using the plug in that came inside the Vw2009 dvd or the previus plug in?
  2. Must work in conjuntion with walls, floors and pillar in hidden line render mode.
  3. It worked as you said Pat... The difference is that I was using the Issue Manager to change the Drawing Number.In that way it doesn't work. If I edit it using the double click and enter directly in the title block it works! Anyway, It should work with The Issue Manager, too. It doesn't work if you create a Report and use a worksheet's cell to edit the field, I think it should, too. Thanks again.
  4. Can you write a step by step, Pat. I don't get it to work, maybe I am losing something. Thanks in advance!
  5. I think you are saving it as rtf. Must be a txt file.
  6. Tested again..it worked! First option and the done dialog...
  7. Tested again... with the done dialog (To be sure)... doesn't work. Maybe it's something related to the video card (intel, 144mb, shared)
  8. Jeffrey... the script doesn't work on a Macbook, intel core 2 duo. Any suggestions?
  9. Interesting... I have some points regarding this: 1. Never get the sheet number: I think it must to be the name of the Sheet Layer... Does this can be? 2. The drawing number: a number asigned to the viewport. 3. Scale: its ok. 4. Name: it's ok 5. Automatically update: Round update. If something changes, all elements get updated. 6. All this can affect the drawing border too. Is there any solution to this?
  10. Ok, the difference was the antialiasing. Was turned off on the imac.
  11. Is there any documentation regarding to these new plug in? Does anyone notice it? Does the new plug in export classes? Is there a way to scale the model while exporting or opening it on C4d? Is the plug in supported by NNA or Maxom, or third party? I successfully exported these elements: Layers, symbols, objects (as geometrically defined), lights, cameras and textures. Thanks in advance!
  12. I'am with Shaun...C4d is the best choice. In R11 with just a few settings you can get excellent results! And don't support Autodesk products!! :mad:
  13. Well...I discovered something today... and Imac with 128mb video, runs perfectly smoth on sections viemports, smoother than my mac pro... what the :mad:
  14. 1. I think it's easier then autocad.
  15. You have to update to Sp1. I think it's a mac only problem with Vw 2008 without updates. Hope this helps.
  16. Witch is your config?, Altoids. I'm working a model from scratch in Vw 2009. I'm more than happy with Vw2009. Remember that Vw2009 requires more video resources than previus versions of vw.
  17. I think these two pages are good examples of content sharing: http://mxmgallery.maxwellrender.com/ http://think.maxwellrender.com/ http://maxwellsky.maxwellrender.com/index.php I hope the swicth to parasolid open the posibilities of Vw for four points: 1. Better modeling 2. Better Objects, including walls, beams, columns, stairs... 3. Interactive programing, like those things in sketchup. 4. 3d Parametrics and 3d dimesioning, like those in solidworks.
  18. Sketchup 7... dynamics compontents, look interesting. http://au.youtube.com/view_play_list?p=B62D27FCCF0C34C7
