pksander
    9
Everything posted by pksander
  1. sorry....actually 2021 SP1..... Most recent release.
  2. Ok looked around a little further and answered my own question. There is an option for 'Object Opacity' in the list of 'other attributes'. Odd that it is separated from the other Attribute Palette attributes.
  3. A small thing, but it looks like you can't currently pick up the Transparency attributes of an object with the eyedropper tool. I have found myself repeatedly trying to do so and am curious if there is a reason it has been left out?
  4. Change the line weight on the selected objects, similar to how 'set size...' works for selected text blocks.
  5. I'm jumping between about five of the preset values. The ability to control click to jump one preset up or down would be helpful. The window/tool/functionality I'm looking for is already coded as part of the software. I'm just looking for a way to get access to it via a keyboard shortcut.
  6. I don't need more than the 10 different line weights. (I probably only use five at most regularly.) What I'm looking for is a quicker way to change line thicknesses. Mousing away from the part of the screen I'm working on to open the palette and accurately select the right line thickness and then moving the cursor back to continue working is much slower than hitting a hot key combination and entering a number. Another option might be if there was a way to control click on an object and get the various attribute changing options. It's a slowness in my work flow that I've noticed over the years that I'm curious if there is away to overcome.
  7. I'm looking for a way to quickly change the line thickness of selected objects. I'd like to be able to hit a hot key, have a window open that I could type a number into and hit enter and change the line thickness. This is possible with 'Set Size...' for text, but I can't find a way to do it for objects. Maybe It's obvious, and already possible, and I'm simply missing something? Any thoughts would be greatly appreciated.
