garry b
    3
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    arch
  • Location
    phoenix,az.usa
  1. vw 8.5.1 will only allow two documents to be visible, i can open more documents, but i can only view the first two i open. when the documents are opened the image will flash then the screen is blank, when i zoom in or out the same thing will happen, the image will flash then go blank. the file sizes are 200k - 400k this is a new problem and none of our other stations are experiencing this. this mach. is a 8600/200 power mac. any suggestions
  2. BRIAN, 8.5.1 SEEMS TO HAVE TAKEN CARE OF THE PROBLEM, WHEN I LOADED THE UP GRADE I DIDN'T KNOW I HAD TO REMOVE THE OLDER VERSION (8.0) (OR AT LEAST REPLACE THE ALIAS IN THE LAUNCHER) AND SO MY DOCUMENTS WERE BEING OPENED IN 8.0 WHICH THE ROTATED TEXED MUST BE A BUG IN THE OLDER VERSION. THANKS
  3. rotated text of more than one line will not plot on our encad cadjet, the lines of text print on top of each other. we use mac plot raster for our plotter driver and has worked with mini cad 7. the text appears correct on the screen and i can revise the text, also it will print correctly from our epson stylus 800. the problem seems to occur with both new vector works documents and converted mini cad documents, any suggestions.
