Keylight
    8
Everything posted by Keylight
  1. Hello, I've attached 2 images. The first is the design layer of a 3D view of some lighting. The 2nd is the viewport created from that design view. I've never had the render visualization lights show up in a viewport like this. I've looked through the normal settings, and can't figure out why I'm seeing those. Thanks.
  2. Sorry just reread your post. A double click did it. It used to be a single click on previous versions.
  3. Hello, VW 2019 SP3 when numbering fixtures manually, how do you stop the process? It used to be by clicking on any other space on the drawing, but that isn't working, and if I hit escape or another tool, the fixtures don't take the numbering. Thanks.
  4. I am using 2019 SP3 if that makes any difference.
  5. I tried this, and it doesn't seem to work. When I exit the plug-in manager and try the tool again, it still reverts back to curtain.
  6. Hello, This probably applies to all plug-in objects. I'm looking to reset the default object properties for a plug-in object. Specifically, is there a way to change the soft goods tool so that it defaults to Pipe and Drape with a specific set of options and text fields? Right now, the tool defaults to Curtain object which I use much less. Unfortunately, this is my template file, so starting a new drawing isn't an option. Thanks.
