rubyredster
    2
    Never
Reputation
0 Neutral
  1. Hi, I cannot render in projection mode Oblique Cavalier. When Renderworks tries to render the model, the view automatically is rendered in top (plan) view. Can someone help me out with this problem. Thanks
  2. Hi, I've tried the following suggestion for importing AutoCAD 2000 dwg. 3D solids: Create a copy of the file to work on. In AutoCAD, export as 3D Studio format. Select All when prompted Options: AutoCAD Object Type, Auto-Smoothing, 5 degrees Then: Insert 3D Studio object - select file Options: Add All, save to layers By Object ... when I do this, I get a message that says "Internal error number 8 - 3D Studio file import terminated". Can someone help me with this? I am running Vecterworks 9.5.2 Thanks.
