Mauricio Rodriguez
    2
Reputation
0 Neutral
Personal Information
  • Location
    Switzerland
Recent Profile Visitors
  1. Hello Joshua, thanks for your reply. I just updated the description. Hopefully it is clearer now. I am in fact using a non-VW Dialog. But it should be possible to work with it I think. Basically I am collecting several objects' Handles in a vector and then I want to query some attributes of the objects (Room Area for example) that I have stored in my vector. This is simply triggered by a WPF Form.
  2. Hello, I have a Plugin (menuCommand) that creates a Form Dialog (non-Modal Form from a C# Module) and from this Dialog I want to call READONLY commands to the sdk (for example: get Object Information of selected Objects in the Drawing). When I call the functions as MenuCommands directly I have no issues. But when I attempt to call the commands from my C# Dialog, (almost any SDK command for example: "gSDK->GetObjectTypeN((Handle)objectHandle)") Vectorworks crashes with the following Exception: System.AccessViolationException". An attempt was made to read or write in the protected memory. This is often an indication that other memory is corrupted". However, I can use the following Functions in the same way without problems: ->GetActiveDocument ->ForEachObject Is this a known limitation from the SDK that it should not be called from another Application? Or is this something I can fix? I have done a similar implementation for other CAD programs that required a form of EventHandler to trigger the SDK Functions. Would this be a viable approach? Or am I missing something trivial here? Thanks in advance for the information. Best regards, Mauricio
