Hi Matt,
Thank you so much for this feed-back and fixed file, and for the time you took to treat my question. It works very well, now !
I thought maybe the problem came from the model I used to create my new landscape projet files, so I created a new file based on the standard VectorWorks model. The only thing I changed in the file preferences is the units, set to meters. And the problem I had initially is still there (same message about the size of the picture, same lack of red and green panels. So if trouble is not coming from my file nor from the model, then i suppose it's due to the software itself, and you'l be quickly fed up with my sending you every file of mine for fixing... Is there any parameter I can (safely...) change by myself ?
Best regards,
Maria
Test Camera Match sans modèle.vwx
