K. Johnson
    4
Reputation
1 Neutral
Personal Information
  • Location
    United States
  1. Is there a way to utilize one keynote legend across multiple sheets? It would be great to be able to use the same legend for multiple sheets when, for example, I have two sheets of Elevations that should contain the same callouts across all elevations. Ideally, these legends could be stored in the resource manager and personal libraries to use across multiple projects.
  2. I feel this is a simple thing, but I'm having trouble figuring out how to do it. Is there a way to change the line color and possibly thickness of classes/layers that are grayed out in particular viewports? Thanks in advance.
  3. I forgot to reply sooner. Thanks for your tip! It is a good solution for this project.
  4. Hello, I am working on a five-story building and have a two-story space where one of the the exterior walls spans across the two stories with windows. If I make the wall in question visible on both the first floor and second floor plans, the windows and doors from the opposite floor appear in the viewport for an inaccurate drawing. Is there a way to change the viewport cut plane so that it cuts through the building at the appropriate height in both the first floor plan and second floor plan? Or what is the best practice for modeling multi-story exterior walls?
