annapla
    4
Reputation
0 Neutral
Recent Profile Visitors
  1. yea that was the problem though. in the screen shot you can see that if I change it to the desired 6500 mm then it still doesn't show. I'm really lost here. I have started a new file so many times as well. usually I just draw a wall, type in the height in the object info palette and done. but this time it just won't extrude no matter what. is there a way to maybe reset all settings of vw? or what is the best way to get on with the file?
  2. Thank you alan and jim! so the video was really helpful. I have done exactly what you did. drawn a shape and then created walls. the problem is that they won't extrude. I can't even set the attributes on 'solid'. maybe the screen shot helps. I just want to set the wall on a certain height and have a brick texture.
  3. thanks for the quick help!! they are on 'none' but thats because i chose a wall style within from the resource browser. if I make them solid than they don't show the cement layers and all in the top plan view right? they will just look like extruded polygons.
  4. Hi there, please could someone help me. I'm tracing over a plan and want the exterior walls to be 6500 mm. wall style brick. and they just don't show up as soon as i go into 3d. is there anything in the walls settings that I can change to make them visible? thanks in advance!!
