rebu1985
42 -
Posts posted by rebu1985
Hi guys,
I would like to try to get a function or script which helps me to calculate automatically the final value attached to the end of a line adding pre-values along the path. As you can see guys below, depends on the value at the end of a line, the script should recognize the value range and show on the drawing the correct diameter dimension/text.
I was thinking if its possible to attach a record format at the beginning of the paths when you select all the lines and create a script which recognize the lines intersections and show the correct value.
Thanks guys!! -
Hi guys,
I have done a script to hide some fields of the default PIO 'Desk' because I just need some parameters to work. The plug-in is compiled right but when its not working because nothing is done. My version is VW14.
My idea is to create different script for default PIO doors and windows but using a few parameters.
My script is below:
PROCEDURE Modifydesk;
VAR
objHd: HANDLE;BEGIN
objHd:= GetObject('Desk');IF objHd=NIL THEN
EnableParameter(objHd, 'Leg Height', FALSE);
SetParameterVisibility(objHd, 'Leg Height', FALSE);
END;
RUN (Modifydesk); -
Thanks guys, i was checking the Resource Browser as you mentioned and it´s true, its really easy to do it manually!!
Im using the VW 14 and the only options to choose are Apply, Import and Reference in the Resource Browser so I cant modify manually.
Hi guys,
I have created a predefined text style to use in my standard dimensions options. I was checking to change the text style manually and i cant do it because when i try it the text style changes to a new undefined one. I would like to know if its possible to create a script with modify any text style (font, size, etc) by myself. I was checking the function 'SetTextStyle' but i am not sure if its the correct one.
For example: I have a text style called dimensions with Arial 8pt and bold and i would like to change by Calibri 10 pt and not font style.
Thanks!!
Thanks for your help guys,
Finally I got it! I am carry on checking more scripts. I am so addictive now!! I want to learn more and more!!
Hi MullinRJ,
I have been working on your comments to do my script and i have done this. I still have some mistakes and i guess its about the array function.
Could you help me, please?
PROCEDURE dialogl_Main;
VAR
dialog1 : INTEGER;PROCEDURE dialog1_Setup;
BEGIN
dialog1 := CreateLayout( 'CreateListBox', FALSE, 'OK', 'Cancel' );
CreateListBoxN( dialog1, 4, 30, 10, TRUE );
SetFirstLayoutItem( dialog1, 4 );
END;PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT);
VAR
i : INTEGER;
nl : INTEGER;
layers : DYNARRAY OF STRING;
h : HANDLE;
BEGIN
CASE item OF
SetupDialogC:
BEGIN
AddChoice( dialog1, 4, 'PLANTA 1', 0 );
AddChoice( dialog1, 4, 'PLANTA 2', 0 );
AddChoice( dialog1, 4, 'PLANTA 3', 0 );
END;
1: BEGIN
GetSelectedChoiceInfo(dialog1, 4, 1, i, layers);
END;
4: BEGIN
nl:=NumLayers;
Layers:=GetLNAME (h);
DoMenuTextByName('Copy', 0);
FOR i:=1 TO nl DO BEGIN
DoMenuTextByName('Paste In Place', 0);
END;
END;BEGIN
dialog1_Setup;
IF RunLayoutDialog(dialog1, Dialog_Handler) = 1 THEN BEGIN
END;RUN(dialogl_Main);
hi guys,
I have created my dialog code for copying objects to selected layers.
All info which i have found its about copying objects to all layers but i would like to know how to do it if I just wanna duplicate to selected ones. I dont know how the script should be to transfer the info from the dialog to the object.
PROCEDURE CreateDialog;
VAR result : INTEGER;
BEGIN
id := CreateLayout('Revise Layer Link',TRUE,'ok', 'Cancel');
CreateStaticText(id,4,'Layers:',-1);
CreatePulldownMenu(id,5,32);
CreateGroupBox(id,6,'Layers Options',TRUE);
CreateCheckBox(id,7,'Planta Sótano');
CreateCheckBox(id,8,'Planta Baja');
CreateCheckBox(id,9,'Planta 1');
CreateCheckBox(id,10,'Planta 2');
CreateCheckBox(id,11,'Planta 3');
CreateCheckBox(id,12,'Planta 4');
CreateCheckBox(id,13,'Planta 5');
CreateCheckBox(id,14,'Planta 6');
CreateCheckBox(id,15,'Planta 7');
CreateCheckBox(id,16,'Planta 8');
CreateCheckBox(id,17,'Planta Atico');
CreateCheckBox(id,18,'Planta Cubierta');
SetFirstLayoutItem(id, 4);
SetBelowItem (id,4,6,0,0);
SetFirstGroupItem(id,6,7);
SetBelowItem (id,7,8,0,0);
SetBelowItem (id,8,9,0,0);
SetBelowItem (id,9,10,0,0);
SetBelowItem (id,10,11,0,0);
SetBelowItem (id,11,12,0,0);
SetBelowItem (id,12,13,0,0);
SetBelowItem (id,13,14,0,0);
SetBelowItem (id,14,15,0,0);
SetBelowItem (id,15,16,0,0);
SetBelowItem (id,16,17,0,0);
SetBelowItem (id,17,18,0,0);
SetBelowItem(id,18,30,0,0);
SetBelowItem(id,30,40,0,0);
result := RunLayoutDialog(id,NIL) END;
RUN (CreateDialog); -
Hi guys,
I have been working on the script and i have done this one. The script is still wrong and I dont know the answer.
Could you help me guys, please?
VAR
h: HANDLE;
nl,i,a: INTEGER;
layer : STRING;
dupl,go,ok : BOOLEAN;
Layers: DYNARRAY OF STRING;FUNCTION
result : INTEGER;
VAR id : INTEGER;
BEGIN
id := CreateLayout('Revise Layer Link',TRUE,'ok', 'Cancel');CreateStaticText(id,4,'Layers:',-1);
CreatePulldownMenu(id,5,32);CreateCheckBox(dialogID,30,'Follow objects');
CreateCheckBox(id,40,'duplicate objects');
CreateCheckBox(id,18,'Planta Cubierta');SetFirstLayoutItem(id, 4);
SetBelowItem (id,17,18,0,0);SetBelowItem(id,18,30,0,0);
SetHelpString(a,'Select a layer to transfer your selected object');
SetHelpString(30,'Go to the selected option with the actual visibility settings');
SetHelpString(40,'Select to duplicate your selected object');
END;Procedure GetLayers;
BEGIN
nl:= NumLayers;
ALLOCATE Layers[1..nl];
h:=FLayer;
For i:=1 TO nl DO BEGIN
Layers:=GetLNAME(h);
END;END;
Procedure Drive_LayerClass;
VAR
item: LONGINT;
data: LONGINT;
BEGIN
CASE item OF SetupDialogC
BEGIN GetLayers; IF Layers=layer THEN SELChoice(a,i,ok);
END; OK:=TRUE; END;
BEGIN GetSelChoice(a,0,i,Layers);go:=ItemSel(30);
dupl:=ItemSel(40);
END;
END;
END;
END;RUN(CreateDialog);
Hi guys,
I have found in the forum a topic which i would like to know because it would be really useful for me. You can find below:
Copy object(s) to Paste (this step is performed pre vs execution)
Execute vs
1. VS Brings up a dialog window with available design and sheet layers
2. User selects layer(s) on to which the object(s) to be pasted in place
3. Click "OK"
4. Layer visibility set to "Active Only", the script activates each selected layer
in turn and pastes in place initially copied object(s)
The purpose of this script its to have some objects (stairs, lifts, structure,etc) of a building keep in the same position in different design layers (they work as floor levels).
Laura
- 1
Thank you so much Mullin for you help,
Using your script i have created two kind of scripts in case i need to use them individually. One does on/classes and the other uses the bucket mode. Its easier for me right now designing the scripts one per one to learn.
Hi Pat,
I am so interested in this script as well. All time i have to copy and paste layer per layer each object and I would like to know if its any option to select multiple layers at the same time.
Thanks,
Laura
- 1
Thanks Hippocode,
I was thinking to do that or convert to property line as well.
I have created the script below but something is wrong because the second part of the script is not working.
- I would like to show the visibility on of class called 0Muros at the same time than the active class 0Sup and hide the others but when the script just works showing the visibility of the 0sup and all the others are hidden.
- I tried to add more classes as ShowClass((('0Muros') & ('0Muros2'))); but script indicates that i need a string. Could you help me, please?
PROCEDURE xxx;
VAR
H :Handle;
Active_class : String;
BEGIN
H := FActLayer;
Active_class:= GetClass(H);
NameClass('0Sup');
SetClassOptions(1);
IF ((GetCVis('Active_class')) = 0) THEN
Begin
ShowClass('0Muros');
CallTool(-207); { Polygon tool, Bucket mode }
DelObject(FActLayer);
end;
END;
Run(xxx); -
Thank you guys for your help!!
I have created this script but I would like to ask you 2 questions if you can help me
- I would like to show another extra class class called 0Door plus the active one 0Wall.
- I would like to show a label as the space function indicating the Room and the area. I was thinking to convert this script to Space but i am not sure what is easier and better.
PROCEDURE xxx;
VAR
H, H1 :Handle;
BEGIN
H := FActLayer;
Active_class:= GetClass(H1);
NameClass('0Wall');
SetClassOptions(1);
Message ('Area = ', HAreaN(FActLayer));
END;
Run(xxx); -
Thanks for your help but i think what i need its easier because i have used simple 2d rectangles as walls.
What i was thinking it was to create a script to define a polyline as the contours when you point the area predefined by the rectangles and then use another script to convert to space or using the function convert objects to shapes.
Hi guys,
I would like to create a script similar than the SPACE function but instead of creating the polygon manually I would like to point an area and get the space called room defined by objects called walls. My main point is to save time to calculate square meters of different rooms of a flat.
Thanks guys!!
Laura
Script which adds automatically values along a path
in Vectorscript
Posted
Im using VW 2014 version, so I cant use marionette tool
