Hello,
I have the following problem: I created the network in the appendix, which creates an extrusion body from a polygon called "Test" , offsets the polygon 2 times inwards and substracts them. In order to create the cutting edges, i.e. to obtain individual surfaces, a line is inserted. I would now like to intersect this line with the resulting polygon, unfortunately it doesn't work. If you delete the last planar boolean you can see what the network is doing. I hope someone can help me here.
Thank you very much and best regards.
podest_v2020(1)_v2023.vwx
