alanOfCadventure
    6
Everything posted by alanOfCadventure
  1. Thanks for your examples. Attached is an example of what I am trying to do. A flat shape made of 2 lines and 2 arcs is extruded to form a slab. thanks Alan
  2. I need to create a closed shape from a series of arcs and lines that I can extrude into a solid. I can't see a sequence of nodes to do this. any ideas much appreciated. Alan
  3. I need to create a closed shaped from a series of arcs and lines that I can then extrude to a solid. I can't see a sequence of nodes that supports this sequence. Any ideas appreciated. Alan
  4. Marissa I am probably doing something silly. It make it with convert to plug in object enabled What happens the wrapped object says it is 3D. When a select it to place from my user library the graphics tracks with the full object but as soon as a place it only the first node displays. If I then unwrap it the full set of nodes display but without the wires. any ideas? Alan
  5. Hi I have a wrapped procedure which I want to put in my user folder. When I do this the result is a wrapped object with all the nodes but the wires are missing and therefore a bug results when I used it. What is the correct procedure publishing a wrapped object. I have made it a symbol and the saved the file to my user area I am very excited by the potential of Marionette but am currently at the frustrated stage of getting stuck on the details. regards Alan
  6. How can I compute a point at the intersection of a horizontal plane or polygon with a vertical linear object ( curve ,arc etc). Any suggestion very welcome. Alan
