Hi,
Worksheets are a very powerful tool to extract data from a drawing. The "Excel" layout of the tool is quite convenient, the helper to set database criteria also.
It gets quite more complicated when you set up each column of your database, using functions, keywords and plugins' field references. Functions and keywords are quite well described in the VW help, but plugins field references are very hard to identify: I mean, when you want a column to display the Space custom name, you have to guess the field name to be 'Space'.'11_Space Name Cust'.
I know it's possible to set up a worksheet with the Report tool menu (Tools->Reports->Create report...) and from there to select the fields through the UI, but a huge improvement of Worksheets would be a selector for these fields (it might be in the right mouse click menu, for instance) directly from the worksheet. It would make possible to edit the database columns, to add a new field for instance, without to create a new Report from scratch.
If this option already exists, and I didn't find it, please teach me how to access it.
Thanks.
