kate tracey
    5
Everything posted by kate tracey
  1. I have had no problem exporting a file as a pdf until this incident. I created a sheet layer and although i seem to be able to export it as a pdf file, the pdf document appears blank?actually it looks like the hold page is sort of a faded cream color (??). When I export the file as a jpeg, it is visible as it should be. Is there a setting I inadvertently changed?
  2. thanks for the comment?i went ahead and selected the correct plant symbol (it had had given me options, I don't know why) and selected ok, and it is now available.
  3. Why is it that, all of a sudden, when I try to use the plant placement tool, it immediately opens up a plant setting box, instead of allowing me to select from the selection tool bar for plant placement? Nothing is selected on the screen. All my classes are open.
  4. thanks ..I'M USING 2013 BUT DID INSTALL SP5 SERVICE PACK. still having an issue with the diagonal x on the drawing?.never had this be an issue before.
  5. What did I do? suddenly the title block is bigger than the page when I place the sheet border tool onto a new sheet. I undid, closed out vector works, and restarted? perplexed on this one. I may have solved my problem?I undid a lot of steps, and it seems to have effected a scaling issue?still not sure how I screwed up there. BUT..Now I'm having an issue with a diagonal cross (suggesting a page size?) coming through in all my viewports on sheet layers, and I don't want to print them?any suggestions on how to correct this. I went to document preferences and tried every variation I could think of.
