cbaarch
    173
Posts posted by cbaarch
  1. make sure you are in the Design layer(s)
    Use ctrl-A to select all objects
    then zoom extents to see what is in the file
    then go back and select an object using the Lasoo mode
    what information do you get in the Object Information palette?
    if it is on a sheet layer are they part of a Viewport?
  2. if you are using vw2008 designer
    you can look for x-frog trees
    these work but expect your file to be very large
    and
    -lines should be used sparingly
    use objects to create elevations
    use walls for trim
    polygons with fills for walls use pattern if printing b/w (which both foreground and background same colour)
    windows use polygon with gradient fills etc....
  3. in the navigation palette
    go to viewport section
    double click on the viewports it will show the vp and on the sheet it resides
    then change the class to None
    we put all our VPs in None Class at creation
    because None class is usually always on
    or we can find it, if lost for whatever reason
  4. some thoughts no specific solutions
    check which version of Quicktime you are running
    and then try using OpenGL rendering
    since you have renderworks why would you not use Fast Renderworks?
    and make sure all your VP's are set to None Class
    that way it is not a class visibility problem
    usually a VP only needs updating if there is a change to the design layer
    if all things are set in the design layer you can use
    Cache Viewport in the Document setting
  5. another approach
    in vw2008
    you can assign a prefix to classes when you import an acad file
    which will create a subclass so it it does not clutter the classes pull down menu
    i.e windows-screws
    windows-part
    etc...
    and in the RB create a folder in the symbols category
    call it windows and move all the windows pieces to the new folder
    which will unclutter our main RB window
  6. the one thing you have to consider
    is that when you use "active class only" to look at a layout
    and you have a symbols with numerous classes the symbols will not show up even thought the symbols is inserted on the class i.e. None
    and all the items inside the symbol are on different classes
    as for the above methods they are both OK
    it depends on what you want to do with the symbol
  7. the sheet layer(s) are always set to 1:1
    the design layers recommendation is to set to a scale that you may be using to print
    the latter let you use the actual point size of fonts of gthe final product
    scale tool should be inserted in the VP that way it will take the scale of the VP automatically
    we have redone our title blocks to 1:1 so we can insert them on the sheet layers
    if you change the scale of the VP you can adjust fonts etc in the advanced setting box
  8. vw purges the selections you want
    if the layers or classes contain information they will not be deleted
    to get rid or move the info
    turn Active Only on and select all to move the info
    or
    delete a class that has info comes up with a dialog that lets you move the info to another layer
