quote:
Originally posted by PeterT:
We are running VectorWorks and plot to our HP DesignJet 230 using Microspot's Raster Driver, but for "out of the office" plotting, we have a similar problem in that our service bureau cannot use our plot files, and they don't own VectorWorks.
As a work around we have found that Adobe Acrobat is great. If you purchase the full version of Acrobat you can save your VectorWorks drawing as a PDF file.
We have done this with our service bureau as a test. We Plotted a "D" size drawing on our own plotter, then we made a PDF of the same drawing, and sent it to our service bureau.
When we got the plot back from the shop we laid it side by side with our own plot, and you could not tell the difference between the two.
Hope this helps,
PeterT
Peter,
We think we solved the problem. I should say that VW Tech Guy Matt Giampapa solved it and his instructions are as follows:
Ok, here you go, the new and improved (and tested version)...
To create a HPGL-2 .plt file using VectorWorks 9 and MicroSpot MacPlot
5.1.2 w/ GraphicPak
1. Install the MicroSpot software.
2. In the Chooser, select the MircoSpot Raster driver, and enter your
user information. Name, Company and Serial number.
3. Here you need to select the printer that your print shop is using, or
the closest you can find. For this example I am going to select the HP
DesignJet 455CA. (We have one here to test the file with at the end) You
should also set your paper category as well. Here I am using US Arch
since our 455CA has a D sized roll.
4. Using the Setup wizard from MicroSpot, you will need to select that
you wish to print to a "command file". (You should also be able to just
change your destination to file in the print dialog as well)
5. Open VectorWorks 9.0.1 and the document you wish to print.
6. In the file menu, select "Page Setup" and select the paper size you
will be using at the print shop. I am using the Arch D sheet set to
landscape mode. Click "OK".
7. Go to the Page Menu and select "Set Print Area..." and make sure you
size menu is set to "One Page". This ensures that VectorWorks knows how
to set the print area in a way that accounts for the minimum margins for
your printer.
8. Use the "Print" command in the "File" menu.
9. In the upper right hand corner, change the "Destination" menu to
"File"
10. Click on Save, then save the file as "SomeFileName.prn" or
"SomeFileName.plt"
All you should need to do is either email this file, or save it to a PC
formatted disk and the print shop should not have a problem with it. The
only hitch that may come up is if you are using a printer which MacPlot
does not directly support. But, even in that case if you choose a
printer that has similar hardware it should work, or you can use the
Setup Wizard to use a custom printer that is not in the list. (I did not
see any way to do this in the chooser however)
Once you bring the file to a Windows machine, sending it to the printer
simply requires going to the command line and typing, copy filename
"path to printer". So if the printer is shared on the network for
instance, it would be "copy myprintfile \\server\printer".
So there you go and good luck and thanks for the PDF solution. Go A's
Terry Murphy
