79 -
Posts posted by zuken86
Yup I do not see that tool. Fundamentals is very limited!
Thank Vincent. It works just as you described it.
@Mike: I was just trying to figure out a quicker way to hide/unhide a class without opening the class visibility panel every time.
Vincent, I did what you said and Vectorworks seem to recognize the script but the script does not work? I modified my workspace and added your script under View. I created a simple object and put it in its own class...With the object still selected, I went to View --> Toggle Class Visibility...but nothing happen?
Vincent C,
I am running Vectorworks Fundamental 2011...I will try to put it in Plug-ins folder but I afraid it won't work. Thanks!
Hm...for some reason I cannot import .vsm file? I am on a Mac if that makes any different. I went to File --> Import --> Import VectorScript.
Where can I find "Select Similar" tool? I am running Vectorworks Fundamental 2011.
I thought it might be useful when creating Key Notes!
Is there a way to create a symbol, name it and then set it up so that when you drag an instant of that symbol from the library, it's graphic and name will be displayed at the same time?
Thanks!
Thank Miguel
How do you create that break (------------------) in Object Context panel under workspace modification?
Thankssss!
Good morning,
I am just wondering if there is a way to quickly select all objects by class and right click to access class visibility options. Can I modify the popup panel shown when I right click on an object?
Thanks,
I did restart and it still did not work. I am using Mac OS X 10.6.8 with Vectorworks Fundamental 2011.
I have a panic situation. Basically I have been working on a huge project...I periodically save the file and its backup. Just a minute ago, vectorworks crashed on me and now I cannot open the file as well as a backup file...It basically showed me this message and all of my works were gone. Please helpppp!
I think I just got it to work. After joining the two arcs with Connect/Combine tool. I converted it into a Polygon and then use the Duplicate Along Path...and it works!!
I have Vectorworks Fundamental 2011. I joined the two arcs together with connect/combine tool (I used dual object combine mode). Shouldn't it be treated as one single path after they are joined together?
Hi,
I have been messing around with "Duplicate Along Path" tool and it seems to work with a single path. When I tried it on a Polyline path created by joining two single arcs, it didn't work. Any suggestion? Please see attached!
Thanks,
Oh i just figured it out. The problem was that I was trying to use 2D drawing tools in 3d mode
This is so bizarre. How come my snap to working plane disappear once I select a drawing tool to start drawing ??? I don't understand it at all! Please help!
Hi, is there a way to render the edge of object in final renderwork ... similar to the way final shade rendering is?
Thanks,
Thanks so much! It works... It is "Smart Edge" snap on my version of vectorworks and the hotkey is "F" in 3D mode.
Hi I have been trying to draw in 3D mode but for some reason 3d snapping doesn't work so well. Whenever I tried to snap to a point of an existing project at a certain height, it always project my snap point down to the 0 of Z coordinate.
Thanks,
No wonder why it doesn't work. They are 3D objects. Thanks much...I learned something today
Hi,
I have two objects; each object belongs to a class. I was messing around with the opacity slot under class tab but could not figure out how to make it work. I turned the opacity of one of the class object to 5% but it still shows at 100% on screen. Am I missing something?
Thanks,
Drawing label and scale?
in General Discussion
Posted
How do I get the scale in drawing label to display a drawing's scale? "Actual Size" doesn't seem to go away!
Thanks,
