windtravels
    6
Everything posted by windtravels
  1. Great that explains todays problem... kind of embarrassing. thanks. what about the multiple object selection problem? just a one off bug? seems to be working again today.
  2. Hi, Using Vectorworks 2008 fundementals on mac 10.6.8 osx. Strange problems, or bugs, have been occurring. Yesterday I could not shift-select multiple objects, and today when clicking on a rectangle (for example) no blue anchor points appear, so I cannot reshape the object. Anyone have an idea as to what is going on? Thanks.
  3. Aha, now I see. Knew it had to be something simple/obvious I'd missed. Thanks!
  4. Hi, When I change the class of an object or multiple objects it changes the colour settings of the object to that of the class. Is there a way to stop this happening? I want all the objects to keep their colours but change class. I have 'use at creation' unticked. Thanks.
  5. Thanks for the reply. Ah, I was worried that might be the case. Will try upping to 1200 as a work around then. Cheers!
  6. Hi, Couldn't see this problem posted anywhere on the boards so here goes: When exporting to pdf (both print>pdf and file>export>export PDF (quartz only) with Vectorworks 2008 SP3 (on a mac, with dpi set to 300) dashed lines that are not horizontal or vertical appear wobbly, not straight as they should be. They follow the correct path but each dash is slightly off the angle it should be, and each at an apparently random angle, up to around 30degrees. This problem seems less pronounced using file>export>export PDF (quartz only) but is still clearly there. Does anyone have any advice with this issue? Its driving me nuts! Thanks.
