Henners1
    5
Reputation
0 Neutral
Personal Information
  • Location
    Cirencester
  1. Hi I am using the property line tool to add an annotation to a number of different polylines. Does anyone know a way of the annotation being ....ha rather than the default ...hectares? I know you can edit it once ungrouping the annotation, but if doing this there is no real benefit of using the property line tool. Many thanks
  2. I am trying to use Ordnace Survey Shape Data from Vector Map of Great Britain. The boundary data is fine. The text data is a problem because it is data attached to 2D loci. I know there are some clever VW users out there who may be able to help. Does anyone have a script that can return the appropriate data as text on a layer. Please see attached PDF of dialog box of data. Many thanks
  3. When importing a Bitmap into vectorworks using my PC, all the lines/images appear to be surrounded by a white border (even though the lines/images are black). This becomes very inconvenient when working on the white sheet as I can barely see the image. When zooming into the image (as close to line as possible), the white seems to disappear and when printing it also does not appear. Is this a problem with the Graphics card on my PC, or the way I am bringing in the Bitmap image? Thanks in advance!
  4. I have recently installed DIN Open Type font onto my PC in order to use the same font as my work colleagues using MACs. The problem is that Vectorworks 2011 seems to display the font onscreen as Aerial and only when the document is printed that the text is DIN OT. Does anyone know why this is happening any how I can get the DIN OT to display onscreen? Thanks in advance!
  5. I have installed DIN Open Type font onto my PC in order to use the same font as my work colleagues using MACs. The problem is that Vectorworks 2011 seems to display the font onscreen as Aerial and only when the document is printed that the text is DIN OT. Does anyone know why this is happening any how I can get the DIN OT to display onscreen. Thanks in advance!
