lutyens
    4
    Never
Everything posted by lutyens
  1. Thanks Matthew, I've managed to crack the extrusion of an arc to create the curved roof but still getting confused as the roof appears at different heights on different drawings. Also the 'left' view is showing the 'back' and the 'right' and 'front' are showing the front elevation! I assume it's the working planes that are the cause. Is there a way of returning to the Architect 'defaults' on all 'sheets' so that heights and elevations correspond correctly? Regards,John KellettChartered Architect (UK)
  2. As a beginner with Vectorworks Architect 9.5.1 and trying to get to grips with the software without the expense of training (I have to use AutoCAD LT in the office!) I am having difficulties trying to create a curved roof. Is there an easy way to achieve such a thing in Architect. If not, how does one rotate an extruded 3D form and place it in the right place/class/layer/sheet without getting confused! Any advice? Regards,John KellettChartered Architect (UK)
  3. Thanks Mike for your reply. I think I've dicovered the solution. The UK distributor here in the UK believes that the problem is a duff 'dongle' as they had received a batch of faulty ones. Here's hoping....... On another note I understood that VWA 9.0 is only one CD as it is no longer an 'add-on'. The single CD is labelled 'Vectorworks Architect' and appears to feature, when loaded, the 'Architect' elements! regards, John K
  4. I've successfully installed VWA 9.0 on an iMacSE 600 Mhz running OS 9.1, but the programme will only run in demo mode! The software did not ask for the serial number on first use so I have installed it using the 'session' dialogue box. I have also shut down and restarted the computer but the software will still only run in demo mode. HELP! Regards, John Kellett
