Actually, that didn't work for existing tree tags or other plugins with fields that sit above each other. Regular callouts have to be adjusted through 'format text' and styled as callouts with single spacing.
hmmmmmmmmmmm.
Any text, be it a callout, plant tag or simple text that should appear as multi-lined is now showing as a single, garbled line with lines of text on top of each other. Has this happened to anyone else?
Thanks,
Daryl
I'm trying to add a 'spacing' column to a plant list that will relate the spacings plants in a landscape area. Nothing I try as a formula seems to work. Any suggestions?
thanks
when we were running VW'08, we could butt join walls at an odd angle, delete one and still have the other retain the angled end cap. With version '10, the walls heal automatically when separated. Is there a way around this?
also, how do we dis-associate walls so they don't stick together when one is moved.
