154 -
Posts posted by Musisback
Good idea I thinks I'll be able to work something out.
Maybe, I'll fill the parameter in the kObjOnInitXProperties event. so I need to read the data once only for each object type.
Hello,
I would like to use external data (tab separated or comma separated)in my PIO's
The "read file" method works fine but I don't like the idea that VW needs to read the data each time the PIO recalculate.
I don't want to use .px files because I don't want to encrypt and distribute my plugins again each time I change the data.
I could use .vss includes, but it seems that we can only write code (not raw data) in those.
Also, if I write a function in a included .vss file, I cannot encrypt the plug-in anymore...
So, how can I do?
Thanks
They have. There is some kind of logarithmic or square root relation between the "set Brightness" and the real brightness and I cannot figure out what it is.
10 lights set on 10% don't light nearly as much as 1 light set on 100% (seen attachment)
Does someone know the relation i'm looking for?
Howcome 2 lights set on brightness = 50% appears darker than on light set on brightness = 100% ?
Is there some way I can calculate the brightness of 10 lights if I want them to be as bright as one light set on 100%?
Thanks,
One of my PIO's defines the position of other PIO's. The users sometimes delete it by mistake. I would like to display a warning message when they try to delete it. Does someone know if this is possible?
Hello,
The white is transparent in rendered viewports. This can be annoying may the sheet background is not white. Is it possible to disable that?
Thanks,
Thanks Raymond, It works fine.
I have an extra question though. How do you find those constants?
I couldn't find it in the appendix or anywhere on the sites :
www.vectorlab.info &
developer.vectorworks.net
Are they other interesting websites I should know about to help me find answers by myself ?
Thanks,
Hello, I have 2D Custom tools that work only when the active plane is "screen plane". So if I change the active plane to layer plane, they don't work correctly.
How can I change the active plane to screen in my tool script?
Thanks,
I actually don't know much about C++ but what I implement is really becoming to complex for VS. I need to get conformable with SDK, but that is a big step forward...
Is there a forum that work good for that?
(This one does not seem to bring much answers to the persons asking questions...)
Thanks,
Hello, I develop quite complex PIO with Vectorscript but I loose lots of time rewriting basic function that are not available in Vectorscript. (String editing, 3D calculation, Lists sorting...)
Those function are of course available in C++
Do you now if it is possible to create VS functions with the SDK?
Thanks,
Damien
Do you now if it is possible to create VS function with the SDK?
Thanks,
Damien
Thanks,
It is not as nice looking than the VW Criteria dialog (because we see the dialog close and open again) But it works fine..
Does anyone know how to create a dialog with a number of choice that can be chosen from the dialog itself. (With a button "More choices" for instance.
The VW Criteria dialog is the perfect example (see attachment)
Another way to see it is a button that changes a the number of choices and resets the dialog. I cannot manage to do that.
Thanks,
No one else has experienced this problem? Or better : Has a solution for it ??
Thanks,
Thanks,
This works and gets me in the 2D component editing. Do you also know the constant for the 3D component?
Or do you know where I could find the complete list of those constant?
Thank,
Is it possible to display the symbol editing environment from script?
I have a PIO that contains a symbol. I would like the users be able to edit the symbol directly from the Object Info palette of my PIO without going through the Resource browser
Thank,
Sometimes, there is a value that stay stuck in the databar when drawing walls. It usually happens when I make a view change by mistake while drawing walls.
The Length I type is locked after pressing enter, but has no effect (constraints)
When this happens, I found only one way to make it got away : restart VW.
Does someone know what causes that and how to avoid it?
Well not in my version or there is a hidden option somewere
See attached file
VW2012 US SP2
Hey,
Does some-one know if it is in Nemetschek agenda??
So it really looks like it is impossible.
Why do Nemetschek so often develop new features only half way?
Maybe will have the answer in VW2025...
I don't see this check box in the OIP for Section viewport as a see it for regular viewports...
I can't manage to make 2D objects in 3D (like dimensions) appear in the section viewports. Can some one explain how to do, or is it impossible?
Thanks,
Thanks,
Thanks for the ideas. Josh, it sound very interesting, I would very much like to hear more if it is possible...
Vectorscript Development Tools for Windows: Notepad++
in Vectorscript
Posted
Hello,
It seems that this comment type is not taken into account :
Comments
I sometimes use them because the other comment type can be included without creating errors.
