Thanks guys, great help. That's an interesting way of getting the object to be scaled, especially in VW. I would've thought the method would be more visual than textual or input based.
Ray, that's the only way I could figure out how to do it originally, but that way seems like the longer, less precise way. If I'm understanding your way as the same way I tried, the scaling is sort of 'blind', and requires you to continually move the object back over the drawn line to check if it lines up. It will work fine, though, in certain occasions, and may work best for you in what you're doing. However, precision is paramount when matching the imported images for me.
Edit: Sorry Ray, I went back and re-read your advice, and it seems I misunderstood at first. But when importing the image, I have no idea what factors I'm looking for, so that still doesn't seem to be the best way for me.
Also, what's up with the 'fixed point' command? How does that work? I keep getting that same error, but that sounds like the tool I'm wanting to use...
Thanks all of you for the advice. I'm loving VW more each day, but I'm sure I'll be back with many more Q's along the way!!
