GaryJB
    11
Everything posted by GaryJB
  1. Vectorworks 2008 Machine Design
  2. How do you get rid of quandrant lines from a curved 3D surface after you subtract and object from it? I do not want to render it just hidden lines or dashed hidden lines.
  3. Ok, In Edit/Duplicate Array/Rectangular Array, for example I can setup 5 columns, 5 rows, stacks is grayed out with (8) in background, distance columns is 2, distance in rows is 2, dist in stacks is grayed out with 25 in background. Hit Ok and I will get 5 rows and 5 columns of my object with 8 duplicate stacks on top of each other. Hope this will help.
  4. number of stacks field is not available in linear option. I have tried changing all fields within all three options inside of duplicate array, it seems that I do not have any choices to change the stacks field in rectangular array.
  5. the option is set to retangular array.
  6. This sounds logical. The number of stacks field is "8" but it is grayed out not allowing me to change this.
  7. Can anyone explain why in top/plan view I will duplicate a single 2D object in a linear line with a (X) dimension and it will duplicate each object 8 times at the chosen (X) dimension?
  8. Thank you, this is very helpful I have done something similar but this is a far better representation.
  9. How did you go about this? I have tried subtracting 3D threads from a solid and VW comes up with an error saying: You have tried to created a solid object which cannot be computed. Edit geometry to resolve this condition. Thanks
  10. Is there an easy way to make 3d interior thread?
