Bruce Ferguson
159 -
Posts posted by Bruce Ferguson
Tom,
Did you update both the model file and the site model file to VW 10 files? Then are you saying you opened the site model file in VW 10, and you tried to reference the VW 10 model file and you got an error? That sounds like a problem with VW. You could send me the 2 files, and I will investigate.
Thanks,
There is no absolute limit to the number of layers you can have. But for large numbers of layers, you may encounter problems. As the number of layers gets larger, it will get more difficult to use the layer popup menu to set the active layer. Also due to a limitation in the Mac OS code for listbox controls, the layer setup dialog will not show all the layers when the number of layers gets too large (this will probably not happen until the number of layers is more than a thousand, and the number of layers at which this occurs will be smaller if the layer names are longer).
What version of VW are you using? I tried this on VW 10.1, and I didn't see it happen. What platform are you on? What do you have checked on the eyedropper preferences dialog?
Thanks,
Geoff,
This is a problem with VectorWorks. There is already a report about this in our database.
Thanks,
Could you send me a testfile and explain what to do to see the problem?
Thanks,
Dave,
After doing what Katie said, you then need to change the dimension standard for all the dimensions you have already created. If they're all on layers with the same scale, I think you can edit them all at once. I would make sure all the layers with dimensions are visible and set your layer options to Show/Snap/Modify Others. Then do a custom selection, making the criteria that the Type be Dimension. Then just go to the OI palette and set the Dim Std to ASME Dual Stacked (if this standard isn't quite what you want, you can make a custom standard from this standard).
BAZ,
I can't think of why this would happen unless you have the Use Layer Colors preference on in the site plan document. If that isn't on, you could send me both of the documents, and I will investigate why this is happening.
Pete,
Do you have the 8 selection handles preference on? If so, turn it off and the extra lines should disappear. We are addressing this display problem for a future version of VW.
This notification means that there are some objects that are visible in the source file that are not visible in the file with the reference. You cannot turn off this notification, but this issue is being addressed for a future release of VW.
ga, VW has been improved in this area. What version are you running? If you send me a file with instructions for how to see this problem, I will investigate it.
Ion, there was a problem when zooming when you're entered into a group with show other objects on that was addressed for the next release of VW. But you said you see a problem after exiting the group. If you send me a file and instructions for how to see this problem, I will investigate it.
Thanks,
Thanks,
John,
If you send me a file with a line that has the display problem when zooming, I will see if I can duplicate it here.
Thanks.
Please send me a copy of your file, and I will investigate this problem.
For the problem with not being able to access all your fonts when you have a large number of fonts on your system, there is a Format Text menu command in VW 10 which brings up a dialog that has a list of all the fonts, and you can access them all. Like the font menu, this sets the defaults if no text is selected, and it sets selected text objects if text objects are selected.
No, this has not changed.
The second fill was added for v10. It is just there when the text offset is 0. It was added because of a complaint that the break in the dimension line was not large enough for ASME dimensions. It's size is a little larger than the text fill in both directions. I think the problem you're seeing with its size would be solved if it was only bigger in the direction of the dimension line. We will investigate this.
Not being able to turn off the fill behind the dimension happens when the text offset is 0, such as when you use ASME dimensions. This is a known bug.
You cannot change the location of the backup folder. It will always be in the same folder as the active file.
Mickey,
When you did the duplicate array, did you use the Ctrl+Alt+D keyboard shortcut? When you have the symbol insertion tool selected, pressing the alt key temporarily switches the tool into pickup mode. If you do the Ctrl+Alt+D for duplicate array, the symbol tool is left in pickup mode. To then insert a symbol, you first need to go to the mode bar and click on the far left button, to return it to insertion mode.
Gavin,
For the problem with disappearing lines, please send me a file and an explanation of how to see the problem.
bickel76,
I'm not sure what you mean. Could you please send me a testfile that demonstrates this?
Thanks,
Yes, this is a known bug that is only on Windows. To workaround this, if you want to select class 'A-B-C', for example, then choose Create Script instead of Execute Immediately. Select class ‘A’ on the criteria dialog, then edit the script, changing ‘A’ to ‘A-B-C’.
No there is no way to round to the nearest 5 or 10 in v8.5.2 or in v9.5. We will consider this for a future release.
Being able to snap to and modify gray classes when the options were set to Show/Snap/Modify Others in 9.0.1 was a bug.
It sounds like you are referring to a bug that was introduced in 9.5b7 where arcs were not mirrored correctly. If so that was fixed for the final version of 9.5, which is now available.
Mysterious Crashing
in General Discussion
Posted
Michael,
This problem is being addressed for a future version of VectorWorks.
Thanks for the feedback.
