VincentCuclair
3,105 -
Posts posted by VincentCuclair
Good for you Ozzie
OK here's a little more:
The error message:
Problemsignatur:
Problemhändelsens namn: APPCRASH
Programnamn: SketchUpWorker.exe
Programversion: 0.0.0.0
Programtidsstämpel: 55005381
Namn på felmodul: SketchUpWorker.exe
Modulens version: 0.0.0.0
Tidsstämpel för felmodul: 55005381
Undantagskod: c0000005
Undantagsförskjutning: 000000000001465e
OS-version: 6.1.7601.2.1.0.256.48
Språkvariant-ID: 1053
Ytterligare information 1: bab3
Ytterligare information 2: bab30863d3a16f1b446d293cc6b9dbda
Ytterligare information 3: ea93
Ytterligare information 4: ea938fecf28aa4ee8e9c933d7bbed529
Never mind this morning all was well again?! (I really got to get this office to change to Mac )
Windows 7
Exactly, works on my Mac but on PC it gives a warning that SketchUpWorker.exe has stopped working?
OK here's another one: my Vectorworks 2015 (on Windows 7) doesn't recognize my Swedish keyboard?
(Works in Photoshop, Revit, Autodesk Architecture, SketchUp etc on the same machine....)
Any ideas?
If I try to start SketchUpWorker.exe directly from Finder (or what ever it is called in Windows) it says Systemerror because slapi.dll is missing?! Anyone?
When I try to import a SketchUp file I get a dialog stating that the SketchUpWorker.exe has stopped working?
What do I need to do to get it working?
Not even typing a letter helps in jumping to the correct place!! :mad:
OMG that is horrible....I have 350 classes!
OK this is new, started working on a Windows 7 machine and I can't mouse wheel scroll the classes pull down list ie. when I want to change the active class and/or when I want to change a selected objects class in the OIP. (Only the little arrows at the top and bottom work....)
Any ideas?
OK, so I created a Roof Object with a couple of dormers (Roof Elements) using the Create Roof command, all is well, looks good, time to make a couple of sections = Oooops! :blush: !!!
Seriously! BIM or Hobby software?
Nope but it has been wished for.......
http://needleandmortar.com/wiki/door-tool-improvements-2015/#4-door-id-tags
I use Pat's script: https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=108487#Post108487
Just select an object and run the script. For windows and doors, insert a window or door outside of a wall, and run the script on that. It doesn't work on objects inserted into walls.
hth
mk
Yeah, that's what I've been doing too, but I find it mind boggling that there isn't a comprehensible list at all, how on earth are we meant to use Vectorscript without it?
How do I find Field Name scripts? Is there a list?
I want to call a certain 'door field value' under say Door Field Name 'Manufacturer' (which apparently is 'Manuf' in doors and 'ManufSupplier' in Windows) where do I find a list of the script values of these (all) Field Names?
+1 (the push/pull tool should work on everything incl.PIOs without destroying their intelligence)
+1 and an option/tool for down spouts would be much appreciated too!
It would be nice/logical if the Sash Width Offset also worked/could be set for Mullions too.
I'm trying to create these types of doors/windows:
- 1
I like that, either a contextual item in the right click menu per-wall, or a menu command to "reset wall peaks" that could take one or more walls in its selection.
Submitting request now.
Perhaps a simple check box in the OIP one for the wall tops and one for the wall bottoms?
Here's a script that does it to degree (read the thread above to see why not completely):
Procedure Fix_Walls;
var desired_ht:REAL;
PROCEDURE HandleWalls(h:HANDLE);
VAR result:BOOLEAN;
BEGIN
ClearWallPeaks(h);
ResetObject(h);
END;
BEGIN
ForEachObject(HandleWalls,SEL);
END;
Run(Fix_Walls);
Import SketchUp problems
in General Discussion
Posted · Edited by Vincent C
Don't know, it works on my Mac which is 'Swedish'.
(I just started at this office, they use Autodesk but I need to finish off some existing projects so I installed VWs on my office machine over there and subsequently got this problem, I'm not saying it is a Windows thing but I sure am getting a lot of small irritating jinxes all around giving me flashbacks to my time prior to Mac
I'll try to set the language to English ad see if it helps......
