AnaisR Posted January 15, 2004 Share Posted January 15, 2004 (on PC, Windows NT) In VW Mechanical (10.5) I have created a Custom Title Block following the instructions in the HelpFile, i.e. creating it with a 1:1 scale. When I have a drawing that needs to be in 1:2 scale my whole drawing border shrinks down too, which is not what I want. A solution to this is to delete my drawing border and then reset it using "Mechanical->Drawing Setup->Insert Drawing Border->Custom Title Block". The drawing border inserts itself fine, but not the Custom Title Block, where the linked text is all messed up. I could set my Drawing Borders and Drawings on different layers, with different scales, but I want my Drawing Borders on the same layers as my drawings since I have several issues of them and want each drawing border to be associated with a single drawing. Why does the Custom Title Block not adust itself to the new scale as the ASME Title block does? I have also tried changing the print area, but the Custom Title Block is still messed up. Has anyone found a way to go past this problem? cheers, anaisr. Quote Link to comment
Guest Posted January 16, 2004 Share Posted January 16, 2004 Hi Anais, Does the title block scale correctly? Is it just the text that is messed up? Is the title block a symbol named "Custom Title Block?" Tom Urie Nemetschek, N.A. Quote Link to comment
AnaisR Posted January 16, 2004 Author Share Posted January 16, 2004 Hi Tomu, Yes, it seems that the title block scales correctly, but the text is messed up. The title block is a symbol named "Custom Title Block" which is saved in a symbol library and imported into my target documents (through the use of a template). I am then importing old Engineering drawings into these templates and want the drawings to fit in one page for printing on A4. cheers, anaisr. Quote Link to comment
AnaisR Posted January 16, 2004 Author Share Posted January 16, 2004 Sorry I forgot to specify, the Engineering drawings I am importing have various layer scales which is where the problem comes from. Quote Link to comment
Guest Posted January 16, 2004 Share Posted January 16, 2004 Aha! That is the problem. If your drawing contains layers of different scales, the title block will not work correctly. What you need to do is to create a separate 1:1 layer for each drawing and place the drawing border with title block on each of these layers. For your final "drawing", make both the drawing layer and the associated drawing border layer visible and all other layers invisible and the drawing layer as the active layer. Set the layer settings to Show Others and you should now have a drawing with its associated drawing border. Save this as a sheet. Once all of your sheets (drawings) are saved you can switch between these drawings using the Sheet Menu button at the bottom of your screen. I hope this solves your problem. Tom Urie Nemetschek, N.A. Quote Link to comment
AnaisR Posted January 16, 2004 Author Share Posted January 16, 2004 Yes, this is the only way around it, I was hoping there might be a different solution but I guess that's what the sheets are there for! cheers, anaisr. Quote Link to comment
