Probably too late for VW2014, but like asked multiple times, we need better attribute controls for classes for use in many places like the autohybrid.
Classes should have 2 fills, one for section and one for visible things. So that when you use an object in the Autohybrid, it will show by class when cut and when seen from above. To take it even further, let us set a linestyle/fill for the invisible part, but maybe this should be a general setting for all classes?
VW really need to be simplified and streamlined. Too many things, too many ways, and they make simple things too hard to get right. Some will not agree with me, but just force the users to work by class and VW can loose so much code and parts that it will be so much simpler and more automatic. It's far more easier to setup classes then all the other attributes for all other objects.... It will also remove so much choose that doesn't need to be there in the first place.... Users will also have an easier time setting up the drawing and will get and see the benefits automatically.....
Dieter @ DWorks
I really hope VW2014 is a start of this....
0 answers to this question
