mar schrammeyer
385 -
Posts posted by mar schrammeyer
Under AEC you'll find Dimension Exterior Walls
Followed your advise bought PdfCompress and excellent result 10.5Mb went down to 2.4Mb checked the result on a pc no problem thank you
You are maybe working in 3D top view instead top plan, you will see a line on the joint then, why auto join is not working i cannot say if everything is ticked
nah found some .ick files whatever they are thanks for the pointer though
i think the answer would be to create a template, having pre aranged vps with the right label etc
thanks Christian, how do i find those invisible files? must say though the work i did after was architural more sound but still it sandboxed ical and numbers, weird
Just worked 3 hrs on a one file, saved to back up folder every 15 min, timemachine every hour, vw froze after exporting to pdf, preview froze, Lion refused to force quit pulled the plug in desperation and found none of my work was saved to either backup folder or time machine, lovely I put this down squarely to Lion.
not a gasbagHilarious, noted as a 'greenhorn' in spite of the fact that I've been using Vectorworks since 2003 and computers and computer modelling apps since 1990. -
i have a 20" screen ( non glossy) next to my imac 21.5" but still use the imac as primary screen i soon did not notice it anymore of course position is important
it pays to read the signatures
they should be found in vectorworks libraries am not sure how much comes with architect
upgraded computer so any speed gain stems from there probably i did a speed check same vp render imac 3.06 12 G ram 10.6.8 (6 min 58), imac 2.5 i5 4G ram
10.7 (2 min 37)
moved over to 10.7 and no significant problems that i could assign to lion since they were file specific
tick zoom line weight in prefs and give yourself a signature with your OS, computer specs and vw
Dutch gable is used here (Oz) for dutch hip in VW talk but originally it would have been a comment like jerry built, dutch courage etc
It is a mystery problem gone thanks for the replies
vw2010 makes a dutch gable no problems but 2011 tells me my gable inset is invalid whatever value I put in, anybody else have a problem there?
you'll have to do some solid modelling, the wall tool does not do leaning walls. a roof plane could work and you could insert skylites as windows but neither will connect with walls
The top exist out of more than one slab 3 actually so you'll have dig a bit further so that the cut out is in all extrudes
Yes see screen shot
no change there, I use a floor as benchtop
It if it something like this(screenshot) double your viewport bottom FQ rendering without any textures applied top one normal top plan view with hatches applied in the viewport
Dimension doors in wall
in General Discussion
Posted
I am not sure what is happening for you then it works for me
